RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   How do I know what is broken (https://www.rcuniverse.com/forum/speed-electric-109/3341642-how-do-i-know-what-broken.html)
Everton 09-08-2005 06:30 PM
well I took my Micro Mono hull out and it fliped over and I got water inside. My RX, servo are fine but ESC or Motor is fried. I don't know what one I fried tho. How can I test to find out before I can buying new ESC and motor. The motor wants to turn but it like jumps now... its odd. Please help me out. Thank you for your time!
jerni21 09-08-2005 06:32 PM
RE: How do I know what is broken
most likely water in the motor, try cleaning it up, or replace it
Ron Olson 09-08-2005 06:47 PM
Hook the motor directly up to a battery pack. If the motor runs, it's the ESC that is gone. My guess is that it's the more expensive part.
raz54 09-08-2005 08:15 PM
It may start working again once it's dry if it is the esc. The motor should still run even wet. In fact some people break them in in water.
Everton 09-08-2005 09:09 PM
I found out what happen.... My motor and ESC still work!!! YA but I bented the prop shaft... :( Thank you again!!!
raz54 09-08-2005 11:01 PM
That's good, it's cheaper to fix that than the esc.
