RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   good setup? (https://www.rcuniverse.com/forum/speed-electric-109/5427007-good-setup.html)
alloutcustom 02-16-2007 10:05 AM
good setup?
i have a super vee bl but will this setup be better?
[link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=2077&image=]motor[/link]
[link=https://www.unitedhobbies.com/UNITEDHOBBIES/store/comersus_viewItem.asp?idProduct=4316]120a esc[/link]
or do u think i should get the 80a one?
thanks for any help,
mike
CadillacDTS2001 02-16-2007 03:25 PM
RE: good setup?
that will work just great
if you can afford the bigger esc (120 opposed to 80 ) then get it
alloutcustom 02-16-2007 03:54 PM
RE: good setup?
ya i deffinatly can. only 10$ difference. is unitedhobbies safe to buy from?
alloutcustom 02-16-2007 03:56 PM
RE: good setup?
oh yea, what kinds of speed could i possibly acheive? ive never run a brushless boat, just brushed.
CadillacDTS2001 02-16-2007 03:59 PM
RE: good setup?
you will get around the same speed maybe a little faster and more efficient.
You will have to change your prop. This feiago is a 2pole motor and the on in the SV27 is a 4 pole. ( more poles more power )
alloutcustom 02-16-2007 04:25 PM
RE: good setup?
What prop would i need? cf or metal?
thanks,
mike
alloutcustom 02-16-2007 04:27 PM
RE: good setup?
also they have other feigao bl's there. is there a different one i should get? for more speed.
alloutcustom 02-16-2007 04:31 PM
RE: good setup?
they have the 12xl, 8xl, and 6xl, the one i was looking at is the 8xl, so what do u think?
CadillacDTS2001 02-16-2007 04:33 PM
RE: good setup?
don't know on the prop CF or metal it doesn't matter. its the pitch and diameter.
as for the wind it doesn't matter its your choice. all will work just great.
also you don't have to post 3 times. Just edit your first post.
alloutcustom 02-16-2007 04:43 PM
RE: good setup?
what have you used to get the best speed? i want to go 45mph, is this acheivable. the lower the wind then more rpm for the same amount of cells right?
sorry for all the questions, i guess im just not knowlegable enough to the point where i can be confident.[&o]
CadillacDTS2001 02-16-2007 04:53 PM
RE: good setup?
ORIGINAL: alloutcustom
don't think the hull will do 45mph.
But i told you i don't have this boat so i know little on what it needs to be setup!!
alloutcustom 02-16-2007 05:04 PM
RE: good setup?
Is unitedhobbies safe to buy from?
SV27dayton 02-16-2007 06:01 PM
RE: good setup?
Have you had the boat in the water yet? OC has seen 42 with the stock motor. I'd say you can get 45 but you better have a recovery unit bc it will be a squirly 45. Get the adjustable tabs too. Sounds like you have the cash to play with. I'd consider longer custom tabs for more stability.
alloutcustom 02-16-2007 09:17 PM
RE: good setup?
ya i was just gonna make two alumminum tabs myself and bend them so they are even. prolly 1 1/2- 2 in long.
yes i have a little bit of money, ive been saving up since i was 6 and im 15 now so u get the point.
i dont have the supervee bl motor yet but i have the esc(it was on backorder but it is coming sunday). I was also thinking of getting a 80a esc to run on the supervee motor. don't know if it could handle it tho.
btw, i dont have a supervee, im using the brushless in it to power my phantom 8 hull from bby
SV27dayton 02-16-2007 11:11 PM
RE: good setup?
Hmmm pretty short boat for 45mph. Sounds like a set-up challenge. Keep us posted.
alloutcustom 02-17-2007 09:40 PM
RE: good setup?
well with a short hull ill be able to turn better and have better aceleration but top speed is a challenge
CadillacDTS2001 02-17-2007 09:42 PM
RE: good setup?
a fast set up will be useless if you can not control it .
go big or go home.
try 38 inch hull
alloutcustom 02-17-2007 09:54 PM
RE: good setup?
ill try this one cause i already have it, prolly will be unstable tho and chine walk too.
CadillacDTS2001 02-17-2007 09:55 PM
RE: good setup?
so if you have the boat then just go for less cells and a smaller motor
alloutcustom 02-17-2007 10:01 PM
RE: good setup?
like what? fiegao 540s or 540l? how fast?
btw, if guys are running there sv27's at 42-45, mine which is only 3in shorter should be fine at 35 or so.
CadillacDTS2001 02-17-2007 10:05 PM
RE: good setup?
the L motor.
alloutcustom 02-17-2007 10:07 PM
RE: good setup?
how fast would it go?
CadillacDTS2001 02-17-2007 10:08 PM
RE: good setup?
on 10 cells around 38mph or faster.
But you would need a 8L motor.
My Name Is Brad 02-23-2007 06:32 PM
RE: good setup?
hahahahaha!!! sorry to break it to ya mike, but if you wanted to go 45 mph, you should of got a bigger hull. There is NO WAY your going to be in control of a 24 inch hull going 45 mph.
have you thought about hull reinforcement?? your going to need it.
also, what about trim tabs?? I'd order up a few sheets of sheet metal, your hull is going to look like a sailboat if you want your boat to be controlable.
not trying to bust your ego, I'm just being realalistic.
CadillacDTS2001 02-23-2007 06:53 PM
RE: good setup?
ORIGINAL: My Name Is Brad
I think we said all this already just a FYi.
and here is another. i have had a 25 inch hull at over 45mph.
and the sv27s are a great example. they are what 26 inches or something ?
well they have shown to do 42mph and they are 2 inches bigger.
do you know the front 1/4 of a mono is useless when its on plane. It does very little. so really a 24 inch hull could have the same size ride pad as a 26 or 28 inch hull
