help i need a battery guy
hi
i am going to need help on picking batterys for two 900 viper xxl motors i dont know how much amps they pull but i like to use two http://www2.towerhobbies.com/cgi-bin...?&I=LC3078&P=1 for each motor it will be moving a 5' 8-9 lb pt boat how would i hook this up though a speed controller ,i am new to battery power and need help ,i cant afforrd pio-ply batterys they say i need 3 big ones each motor at 116.each[X(] any help on this thanks |
RE: help i need a battery guy
those battery's wont do.
a 900 will put about 60 amps . your going to need to run a min of 12 cells each motor and one esc for each motor. 2 of these per motor http://www2.towerhobbies.com/cgi-bin...?&I=LXMND3&P=7 4 in total |
hey thanks can i use two jet 600 navy or one of thesehttp://welasercut.com/lasercart/index.php?main_page=product_info&cPath=41_37_20&pr oducts_id=122 its the sc-480 thanks rye
sorry here the web site http://welasercut.com/lasercart/inde...roducts_id=122
yes you can use one of them
Peter Richards is one of my good friends and the MCD esc's are very good That esc has run two 900 motors with out a problem !. |
hey thanks for your help rye
hi taylor shaw
how do i hook up 2 batterys on each motor to the sc-480 esc thanks rye |
what size batteries?
http://www2.towerhobbies.com/cgi-bin...?&I=LXMND3&P=7 this is what some one on this page said to use whaty do you think thanks rye
oh HAHA . i forgot about that
ok well if you want the most volts for the most speed hook them up in series you will get 14.4 volts at 3800 MAH if you want a good run time then hook them up in parallel for 4600 MAH at 7.2 volts |
ok can i use this http://www2.towerhobbies.com/cgi-bin...?&I=LC2802&P=1
yes that is for parallel. and you will get 7.2 volts at 4600MAH
1 Attachment(s)
ok thanks for your time ,i am new to this kind of power, this is what i am building rye
P109. we have many of them in our club
one has 3 550 motor on one of the SC480 esc's with 2, 8 cells in series. and the motors are in parallel |
this boat is 5' about 9 lb with out the batterys how who you do it only 2 900 motors for speed or long runs i want to get up on plain with it ,rye
i know the boat. they are all the same length.
I would suggest a gell cell "lead acid " battery. of around 4.5 ah( 4500mAh) and around 12 volts that one battery would do the job |
perfect
that one is 7 amp how about this one http://www2.towerhobbies.com/cgi-bin...?&I=LXSK06&P=0
light is good
| All times are GMT -8. The time now is 08:22 AM. |
