RE: STV OPC
One word: Video.
...Please [8D] |
RE: STV OPC
do u have and adjustibval jack plate???
RE: STV OPC
yes i do. i have 1/2 inch above and below to drop.raise the prop and 15 deg. up and down angle on the prop as well.
RE: STV OPC
so try dropping the jack plate all the way down and trimming the motor up about 5 deg
RE: STV OPC
ORIGINAL: crazy maxx so try dropping the jack plate all the way down and trimming the motor up about 5 deg the only thing is to make the boat run wet |
RE: STV OPC
Where's your power coming from Taylor? Less than what I thought if I remember.
RE: STV OPC
ORIGINAL: Taylor Shaw ORIGINAL: crazy maxx so try dropping the jack plate all the way down and trimming the motor up about 5 deg the only thing is to make the boat run wet well mabey run the motor straightwith the jack palkte all the way down |
RE: STV OPC
well i am going to run the jack plate up high and the angle down. its the only way.
the power is a mega 22/20/1 with 6 IB4200's it is a 5500 KV motor on a N2 setup and its a 33 inch boat ( hehe!!) talk about knowing your setup |
RE: STV OPC
try it. if it works thats great...
but ustill need to get some video.action shots of this thing |
RE: STV OPC
i'm only one person. so its usually hard. but i will try some time.
RE: STV OPC
cool
RE: STV OPC
maybe i will get some guys at our club to do it one time.
well i just bought a Lehner4200 KV motor so it will run a smaller prop and have less RPM. this means with the smaller prop i can let it run wet and lose yet still be close to the water not to flip it. should work. but what to do with this motor ?:D |
RE: STV OPC
That's amazing that you can make a 33" boat run that loose with 6 cells. Hats off. I really like it. You need to bribe the neighbor kid or something so you can get a vid. (I'm talking, my own kids don't want to do it unless they get to drive (and the don't).[:-]
RE: STV OPC
Nice. That doesn't look like a 33" hull or are you referring to over all length including the K&B lower?
What is your prop height in relation of prop center line vs bottom of outer sponsons? Where's the video so I can be the judge of speed? [X(] haha Ryan |
RE: STV OPC
you cant judge speed. its to fast for a video. lol
my prop height is the same as the sponson depth. the hull length it like 27 inches and to the prop its 33. |
| All times are GMT -8. The time now is 05:36 PM. |
