RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   the Electric Nitro Vee mod (https://www.rcuniverse.com/forum/speed-electric-109/8820627-electric-nitro-vee-mod.html)
cat samich 06-26-2009 03:30 PM
RE: the Electric Nitro Vee mod
[quote]ORIGINAL: srt10
It all depends on what batteries you are using..
If you go with 3s on the VXL 3500 you should be fine using a small prop..
but if you want to use 4s the kv of the motor is way to kigh for a boat, even on 2s it will have good rpm to run fast.
ORIGINAL: Black0ut
hey. I used to be into nitro powered stuff until i got my blade 400 heli that had a brush-less outrunner 420 motor in it. Electric motors these days are so advanced and powerful.
so here is the scoop.
I have a nitro vee. The local pond doesn;t like the Vee as it is very very loud. The pond is very close to my house, and i rather not drive around looking for a new one. Nitro engines also require lots of maintenance.
It also doesnt go very fast.
I would like to use a Velineon 3500 brushless power system as they came down in price to just over $150.00.
I would like to use the same stock receiver found in the vee.
It needs to be LiPo powered as well.
Does anyone know how i could drive the propeller drive directly without off-setting the motor and using gears?
I also need to mount the motor on the aluminum plate that comes with the boat... any ideas on mounting solutions?
Anybody know of any other motors/ESC that are cheep and fast?
People are telling me that this is too much power... but since when is too much power too much? I mean, i need to at least break the sound barrier.
<br type=
is this directed towards me or the originator of the thread? im going to use the mamba monster 2200 system no vxl for now anyway
srt10 06-26-2009 05:56 PM
Yours..
2200 on 6s is over 48000 rpm!
you will wast the power and possibly rip things apart..
but on 3s or 4s is would be great!
cat samich 06-27-2009 08:10 AM
ORIGINAL: srt10
Yours..
i dunno, im runnin the same system on the same batteries in my 3905 emaxx without ripping anything apart. i may start with 3s just to see what happens
srt10 06-27-2009 09:16 AM
ORIGINAL: cat samich
ORIGINAL: srt10
Yours..
you dunno???
running 6s on a 2200kv motor is a lot of rpms for a boat and will result in problems..
also I think you will have a lot of wasted power in such a small lboat..
sart with a small prop
cat samich 06-29-2009 07:48 AM
1 Attachment(s)
well i got alot done this weekend, havnt started testing yet but here are some update pics. i will get paint worked out after shes a runner.
twoolley08 06-29-2009 08:15 AM
looks good, let us know how it runs once you get it tested!
rebuilder 06-29-2009 05:40 PM
Wow, samich..............................what is that 24pinion and 32 spur............i've always wanted to stick my monster system in a boat (its in my 3905 now) But OMG.............................i think the min voltage for the monster sytem is 14.4v, you might want to check it..................you may need to go 4s, but gear down, have some mercy, BTW i am predicting that you will shred, destroy, liquify your u-drive on the first run, but i hope not. Keep us posted, i would love to see a vid.
P.S. - castle states that the monster 2200kv on 6s is equivalent to about 6 h.p. !!!!!!
srt10 06-30-2009 12:22 AM
ORIGINAL: rebuilder
Castle is a little of on their statements
rebuilder 06-30-2009 04:52 AM
They could be overstating it some, but i'll tell you, they are EXTREMELY powerful, i run my e-maxx on 6s with the 2200 and i've broken lots of stuff on it, its mostly aluminum now, with steel shafts, but i cant think of another motor with more power for $150 bucks.:D
cat samich 06-30-2009 07:26 AM
ORIGINAL: rebuilder
Wow, samich..............................what is that 24pinion and 32 spur............i've always wanted to stick my monster system in a boat (its in my 3905 now) But OMG.............................i think the min voltage for the monster sytem is 14.4v, you might want to check it..................you may need to go 4s, but gear down, have some mercy, BTW i am predicting that you will shred, destroy, liquefy your u-drive on the first run, but i hope not. Keep us posted, i would love to see a vid.
its funny you say that, i took mine out of my 3905 for this project. my intent was to see how things go and determine if i should buy another mamba monster system or go with a 1/10th scale castle system. maybe around 4400kv on 2s. on a side note i try not to show any mercy to any of my rc's. as for the 6 hp on 6s i believe it. my emaxx will do backflips spinning big joe 40 series tires on 4s. on 6s it just starts breaking things. and its a 23/28 gear combo your looking at in the boat. i may go to a 18/28 depending on what happens during the first few test runs. as far as liquefying parts goes i have the castle link on my side. im going to program the esc's traction control feature so its not such a brutal hard start.
honestly though the trx .15 marine is rated at something like .49hp. even if my mamba only made 1.5 or 2hp the performance of the boat would double if not triple. i was bored so i decided to mix it up alittle. after all thats what this hobby is all about.
i should start testing this weekend, i will try to post a video if i can. i still haven't decided on a prop yet. i think im just going to buy a dozen different plastic ones and see how far i get. after i find a good one i will switch over to metal.
srt10 06-30-2009 02:25 PM
ya, that 2200 NEU MM motor is crazy!
as for the over rated 6hp, well.....
NEU rates this motor at a constant 1500watts and peaks at 2500watts.
I have seen someone with a data logger showing a half second peak at 3800watts! he over geared it on 6s to get that peak power and thats just over 5hp! nuts power
2hp contsant power is crazy, no need to get to full rpm to make that power with brushless motors.. the power is right now!
My SV27 FE with a CF48 prop possibly puts out 800 peak watts and got me 41.3mph today.. so your setup is going to be crazy fast!
http://i703.photobucket.com/albums/w...er2009/125.jpg
cat samich 06-30-2009 03:24 PM
ORIGINAL: srt10
thanks man, i really hope to push this hull to 50+. if just for a second. i know i have the power but its all going to come down to gear ratio and prop selection. im pretty sure im going to get the paint all wrapped up tonight and then its off to the pond Saturday to try out as many different props as i can get my hands on. if i can find a camera man i will post up some video
srt10 06-30-2009 04:18 PM
you should get 50+ mph
I would'nt worry much about gearing just prop
start with a small prop and work your way up checking temps every minute or so, and slow on the throttle
rebuilder 06-30-2009 07:14 PM
You could run an octura 447:D and the "monster" would barely get warm im guessin'.........................lets see, hmmmm, 27" vee, 5+/- h.p. brushless, 50,000rpms, 447 prop = 60-65 mph on glass?????? would you dare run a 450?????
P.S. - you beat me to this project, cuz i was gonna pull mine out of my 3905 to try it, but i was gonna go with a 72" vee i saw on e-bay, i'm very interested to see and hear about this..................i'm sorta livin' it thru you.
cat samich 07-01-2009 07:32 AM
1 Attachment(s)
ORIGINAL: rebuilder
You could run an octura 447:D and the ''monster'' would barely get warm im guessin'.........................lets see, hmmmm, 27'' vee, 5+/- h.p. brushless, 50,000rpms, 447 prop = 60-65 mph on glass?????? would you dare run a 450?????
P.S. - you beat me to this project, cuz i was gonna pull mine out of my 3905 to try it, but i was gonna go with a 72'' vee i saw on e-bay, i'm very interested to see and hear about this..................i'm sorta livin' it thru you.
honestly im still trying to figure out the whole prop situation. but the 447 and stock villain prop are supposed to be close to the same and the stock villain prop is what im using as a starting point. so if all works out i may be using a 447 or 450
heres a little teaser on the paint job, this is the hatch covered in 6 layers of autoair lime pearl covered by 6 more layers of lacquer clear coat. its not the greatest pic because i took it with my cell phone but there will be more to come after its all put together.
srt10 07-01-2009 11:38 AM
ORIGINAL: rebuilder
you will not see 5hp out of this setup! that was on 6s and over geared..
motor is only rated 1500watts cont and 2500watts burts...
the motor will only draw the amps it needs to run, it will not always be pulling max amps (max watts- max hp)..
most do not understand that the motor will only pull the amps of what it needs to move
srt10 07-01-2009 11:40 AM
ORIGINAL: rebuilder
because of the rpm you are going to see with this motor on 4s I would find a smaller prop to start with just to be on the safe side!
rebuilder 07-01-2009 12:37 PM
ORIGINAL: srt10
ORIGINAL: rebuilder
Well, Castle states 6hp and your post said 5hp in an isolated situation, and i said 5+/-, i also assumed he was gonna run 6s, why wimp out now when you're building a dragster?:D Also, boats are usually run flat out all the time, the drivers cant help it, its the only speed they know, which results in max amp draw almost all the time.
cat samich 07-01-2009 02:23 PM
i didnt post my build here to start any arguments, if you guys want to debate the actual hp number of the neu 2200 do it in pm's. we all know this motor/esc is entirely to much for the hull. lets leave it at that.
that being said, i will try to finish the paint and start testing by saturday/sunday. hopefully we will see a 50+ mph pass with the ol' girl
srt10 07-01-2009 04:29 PM
ORIGINAL: rebuilder
ORIGINAL: srt10
ORIGINAL: rebuilder
and like I've said before, castle has a high claim on this motor even NUE who builds the motor for Castle says 2500watts max geared proper..
as before the guy who got the 1/2sec spike did it by overgearing his revo.. his constant was about 1600watts with that gearing...
no one is arguing, and so many people post some high claims. When it comes to boats, care needs to be taken or people will be burining up their motors and esc due to someone saying the wrong thing..
boats pull alot of amps and can generate alot of heat if not done right
I would love to see this boat run right and not burn up based on wrong info..
rebuilder 07-01-2009 05:58 PM
I understand he needs to be careful setting up his boat, and i am not "arguing" with anyone i was simply making a statement of awe............like wow, Small boat with BIG motor, Real fast:D........thats all..................if i said the motor had 10,000 hp it wouldnt alter what it really has and it wouldnt have any influence on "burning up his esc" and im certain he's not going setup his electric boat based on some estimated HP figure that the manufacturer claimed anyway, i dont think anybody does that. Samich, i am excited to hear about your run this weekend!!!
srt10 07-02-2009 03:55 AM
ORIGINAL: rebuilder
Love the green paint man!
reminds me of a ZX6!
cat samich 07-02-2009 08:48 AM
1 Attachment(s)
well here's a little update, paint is on and tonight after work im going to shoot the clear coat. if the clear goes on and is set up in time i should be on the pond as planned Saturday. what do you guys think of it?
rebuilder 07-02-2009 11:08 AM
Thats Awesome..............................i'm jealous of your beautiful hotrod.....................i'm eagerly awaiting your 1st run results!!!!;)
srt10 07-02-2009 11:33 AM
Lovin it cat samich !
looks good
