Predator Rigger
I am building a 19" Predator Outrigger and was wondering if I could use this strut and rudder for it?
Rudder: http://www.offshoreelectrics.com/pro...rod=tfl-502b10 Strut: http://www.offshoreelectrics.com/pro...rod=tfl-503b10 |
RE: Predator Rigger
The rudder length might be a bit on the small side. The depth of the strut might not be deep enough. I'm not positive it would work but you might be able to get away with those components.
Ryan |
RE: Predator Rigger
Would this hardware work better? http://www.offshoreelectrics.com/pro...p?prod=mcr-mhd
RE: Predator Rigger
I would choose the previous hardware instead of that.
Ryan |
RE: Predator Rigger
ok thanks, I'll keep looking for something better
RE: Predator Rigger
Today I just ordered a rudder for my 19" Predator Outrigger. I hope it will work with my boat. its the boat off the Pro Boat Widowmaker.
Rudder: http://www.horizonhobby.com/Products...ProdID=PRB3900 I was wondering if this strut would be ok to use on my Predator? Strut: http://www.horizonhobby.com/Products...ProdID=PRB3755 |
RE: Predator Rigger
I did not see any dimensions? Also you want 1/8" prop shaft.
Ryan |
| All times are GMT -8. The time now is 01:38 PM. |
