sv27 wont work
every time i plug in charged batts and turn it on it beeps nonstop unless i turn it off. any help
RE: sv27 wont work
Try to switch throttle TX switch to reverse if it isn't already.
RE: sv27 wont work
ok has that happend to you b4
edit: the throttle reversing swithch is on the N position. is that the normal position |
RE: sv27 wont work
A lot of the ESCs out there will ask for the Tx to be in R (reverse), especially on the Futaba gear...
I have a couple that will keep on beeping until I hold the throttle down in reverse (past the neutral point) and stop... but that will be your new zero, meaning you have to keep the stick in reverse for neutral. Easy on a 4 channel without return spring. |
RE: sv27 wont work
Did you ever have your SV work before this happened ?
Did something get wet ? Try to unplug esc from RX does the servo still work ? Try to plug esc into steering slot on RX and esc and servo into esc slot Will the servo work now ? |
RE: sv27 wont work
yea my sv27 worked great then one day it didnt work. took it all apart and it still didnt work. when it did work the thr. reversing swith was in the n position just liike now.
edit: i just put the thr. switch is r and now it works. how come it switched on itself. it worked on n now its r??? thanx for helpin me |
| All times are GMT -8. The time now is 08:27 PM. |
