cutting down rudder?
Is there a thread or guid to cutting down the rudder on boats that have been modded? I have a cheap 32" that i have modded with lipo and now the rudder is way to touchy. I dont want to cutt to much from it. It this a common practice of cutting rudders? thanks
RE: cutting down rudder?
Have you dialed down your epa's first?
I was going to ask the same. Is switching to lipo the only mod? Is the steering different or is it just that the boat is much faster? I don't honestly know if cutting it down would make the steering milder. You may gain some speed from the reduced resistance but duno about the touchy steering.
ORIGINAL: BACKEMF Have you dialed down your epa's first? |
It will definately reduce drag but if you are going to put a good servo in it and make it go fast you may want the whole rudder. Add enough power and you won't be concerned with rudder drag.
| All times are GMT -8. The time now is 02:57 AM. |
