25
http://www.youtube.com/watch?v=XTUk3mA38E4
my 25" mono with turnigy typhoon 500h outrunner, powered by 2x 2s lipo's in series, 52mph when it had the old 380L inrunner (which got very hot because of crap cooler) hope you enjoy and thanks for looking nick |
RE: 25
I sold my DF 26 with Typhoon 500 motor in it. Now I'm almost done my 29" DF copy and I'll try the newer batch of Heli 500 motors HK has in 1300, 1600 a nd, 2200.
My 1600Kv motor should be here soon. |
RE: 25
2200kv, man i'm getting one of them then
RE: 25
what mah are the batteries??
RE: 25
there 2s, 2800mah, 30Cand i have some 3s, 3000mah,30Cbatts aswell which i want to try out
RE: 25
hi nick how are you cooling it, and what prop are you running on it....al
RE: 25
i'm using a water cooled mount, and i'm using the original 35mm bronze but next boat session i'll a 36mm prop and see how that goes
hows yours coming on |
RE: 25
is the motor staying cool enough for long run times now
RE: 25
oh yes, after 2 minute run its barely warm hence the 36mm prop to try next, i ran the boat 4 or 5 times and only have about 0.6v to put back in each cell, so all in all total run time on 4s was about 10 minutes at full throttle
RE: 25
good, my 25" hor mono is finished, im going to give it a run wednesday night, my new stingers have arrived this morning for the k.o.s. cat, so i will fit them tomorrow, so thats its refit finished, all the bits are here for the 33" mini lynx except the motor moount and esc , so will finish that as soon as they arrive...then i can start the other 25" mono, i all ready have motor for that, im running that on 4s the motor is a 540-10L 2450KV
RE: 25
that should shift, i think they made a mistake putting a 380L motor with the cooler (about 1mm clearence inside) just got to damn hot, they should've put a 380XL inside instead
RE: 25
those hetti coolers are good that i have on, but the o rings are swines to get in, you also have to drill and fit the nipples your self....
RE: 25
i'd rather have the etti coolers, apart from the outrunner, i have them on all my motors, its annoying when the o-ring breaks, i have some acrylic tube coming to make a cooler for the 380 motor plus i have new o-rings aswell
RE: 25
1 Attachment(s)
heres the motor for the 4s version of the hor 25, its 60mm long look at the coolerits the same length
RE: 25
thats completely different to the one i have, its 3/4" the length of the motor, has 1mm clearence between the motor and the inside of the cooler
i've ordered a new typhoon 500H motor from HK, its the 2200kv which will go in my cat on 4s, will give me 32k rpm's, should bring the amp draw down a bit and run cooler, just got to wait for it to arrive now, may even buy the 600H and stick it in the 29" mono |
RE: 25
THOSE 500H 2200KV MOTORS ARE GOOD VALUE AT $19.19+ $9.79 POST
RE: 25
exactly £21 for motor and p&p which is a steal, just wondering what size to use for the 29" mono, might order 2 motors from them
RE: 25
THERE IS FEED BACK ON ONE OF THOSE MOTORS SAY HES PUT 2 IN A CAN AND IT GOES WELL, I THINK ITS THE ONE INYOUR MONO,AT THAT PRICE IS GREAT,
BEEN HAD A LOOK IT IS THE ONE YOU HAVE , 2 IN A 36" CAT HERES THE REVIEW <table border="0" cellspacing="2" cellpadding="0" width="480"> <tbody> <tr> <td> <table width="100%"> <tbody> <tr> <td><a onclick="window.open('HobbyKing_Certified_RC_Hobby _Store_buyer.asp?idproduct=9258&prodname=Turni gy+Typhoon+500H+Heli+Motor+1800kv+%28500+Class%29' ,'HobbyKingBuyerCertified','width=500,height=300') " style="cursor: pointer">Certified Buyer</a> http://www.hobbyking.com/hobbyking/s...crown_blue.jpg <font color="#999999"><font style="font-size: 9px">(74%)</font></font></td> <td width="100"><span id="thumbR129720"> <table> <tbody> <tr> <td onclick="ajaxcats('ajaxrep.asp?idreview=129720& ;custid=52192&rep=g','thumbR129720');" valign="middle" align="center" style="cursor: pointer">http://www.hobbyking.com/hobbyking/s.../thumbs-up.jpg</td> <td onclick="ajaxcats('ajaxrep.asp?idreview=129720& ;custid=52192&rep=b','thumbR129720');" valign="middle" align="center" style="cursor: pointer">http://www.hobbyking.com/hobbyking/s...humbs-down.jpg</td> </tr> <tr> <td colspan="2" align="center"><font style="font-size: 9px">5 thumbs up!</font></td> </tr> </tbody> </table> </span></td> </tr> </tbody> </table> </td> </tr> <tr> <td style="border-bottom: #cccccc 1px solid"><span onclick="ajaxcats('showreviewFeedback.asp?idreview =129720','Rvspan129720')" style="cursor: pointer">I get a 36 inch Catamaran Hull with two of these motors at a speed of 100 km/h !!! At 6s this motor can take a Graupner K Prop of 40mm ! <span style="color: #00f; font-size: 9px; text-decoration: underline">Reply to this..</span> </span></td> </tr> </tbody></table> |
RE: 25
cool, i have a graupner 40mm prop, bu theres a 42mm bronze prop on there and i'm going to try it 5s so i may need to prop down anyway
RE: 25
MIGHT TRY 2 IN THE KOS CAT, WHAT IS THE MOUNTING SCREW DISTANCE IS IT SAME AS A 380 SIZE CAN 19MM
RE: 25
no, i believe its something around 25mm, i had to use the 540 mount for the typhoon motor
RE: 25
CHEERS WONT GO IN THE KOS THEN...
| All times are GMT -8. The time now is 09:57 PM. |
