RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Two of them! :( (https://www.rcuniverse.com/forum/speed-electric-109/9909110-two-them.html)
ryanwilson277 08-03-2010 07:15 PM
Two of them! :(
I have my nitro vee and sv27 at my grandparents andthey both screwed up so please help
1st: On my sv27 i turned on the tx then pluged in the batts and it did its beeps then pulled the trigger like always and it didnt beep and put the throttle reversing swich on then swiched back qnd it beeped so i run it and the steering is unresponsive turn right and it stays right then gliches the goes strait again the the boat keeps going while im not even holding the trigger then stopps and nothing works. I need help figuring this one out any quetions are ok!
2nd: my nitro vees servos have a mind of their own and i dont know what is causing the problem. I Ran it then it goes to full throttle and had to steer it by the dock and catch it and the servo was gliching and holding full throttle then i shut the motor off and the steering servo started turnng to the right so i turned the boat and reciever off and the servo still moved! Please help
ryanwilson277 08-04-2010 08:44 AM
RE: Two of them! :(
Anyone? Any sugestions
NobodyFamous 08-04-2010 02:20 PM
RE: Two of them! :(
I had/have a nitro v as well.  Traxxas servos are supper crapy when they get wet, and in those old boats they got wet.  They tend to have a mind of their own.  You can attempt to open and clean them, but once they have glitches like that, it doesn't take much moisture for them to glitch again.  I would replace the glitching servos in the V.<div>
</div><div>As for the SV 27, I don't know, but it sounds like the rx is shot.</div>
ryanwilson277 08-04-2010 04:14 PM
RE: Two of them! :(
Ok i will get waterproof ones and i keep getting fuel in the hull where a tube goes to the stuffing tube, im guessing fuel goes into the stuffing tube? But its leaking and want it to stop
nomobux 08-05-2010 08:36 AM
RE: Two of them! :(
fuel goes into the stuffing tube <<<< huh ???
ryanwilson277 08-05-2010 01:42 PM
RE: Two of them! :(
Fuel goes to the drive shaft to lubricate it and i thnk its leaking
nomobux 08-06-2010 07:16 AM
RE: Two of them! :(
Post up some clear pics
ryanwilson277 08-06-2010 06:29 PM
RE: Two of them! :(
Ok will do
ryanwilson277 08-06-2010 08:40 PM
RE: Two of them! :(
1 Attachment(s)
sorry about the quality ill get better ones tomarro if needed
