Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
72" mono build, twin weedies
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 04-16-2011, 05:09 PM
martno1fan
martno1fan's Avatar
Default RE: 72
Run both engines normal rotation you wont suffer severe prop walk torque in a large vee,plenty run 56 apaches with twin zenoahs in normal rotation without problems just be sure to use sharp balanced props.,leave the motors air cooled and run the boat open saves a lot of messing arround.That said you can buy cooling jackets to fit the homelite motors or similar but i forget where and you need to remove some of the cooling fins to fit them.
Mart
Old 04-16-2011, 05:43 PM
svranger25
Default RE: 72
ok thats great news, thx mart,,, i still would like to try something like the diagram i posted, ( i'm thinking i can eliminate prop walk and the torque of the engine,,,if any one knows of a 1:1 ratio 180 degree turn gear box and where i can buy it?? can anyone help with this??
Old 04-16-2011, 09:50 PM
svranger25
Default RE: 72
ok i have a pic of progress, what resin/expoxy do i get to cover the entire boat with? links?
opinions on....
http://www.homedepot.com/Paint-Adhes...atalogId=10053
Old 04-17-2011, 04:41 AM
idocdave09
Default RE: 72
This way is not enough needs to be like a zen and the other water cooled engines.
ORIGINAL: svranger25
to what extent off water cooled. i'm thinking i can buy aluminum tubing from home depot that fits between the edges on the clylinder and put water pickups but no pump?
any ideas on my engine setup i proposed?
Old 04-17-2011, 06:33 AM
svranger25
Default RE: 72
i think i'm gonna try air cooled for now
wht epoxy do you use for the outside(something like above^^^^^)
if a boat does have counter rotation should the props spin towards the inside or outside?
Old 04-17-2011, 10:41 AM
  #31
svranger25
Default RE: 72
what is an engine thats a step up from a weed eater engine, without it being rc devoted that will work, chainsaw.... pocket bike...
Old 04-17-2011, 12:34 PM
  #32
Delinport
Default RE: 72
You could use a watercooled Blata or Polini Pocket bike engine. I'm sure you could use an air cooled pocket bike engine in the right hull. The engine shown is a Polini pocket bike engine.
Old 04-17-2011, 01:01 PM
  #33
svranger25
Default RE: 72
thts sick, where could i find one of those and how much?
Old 04-17-2011, 01:14 PM
  #34
Delinport
Default RE: 72
I think if it was me and I was trying to save money I would keep my eye out on craigslist. The engine in the photo is a normal polini pocket bike engine with a custom engine mount. The engine mount really is not that complicated to make....just need a few basic tools like, a drill press, belt sander, metal band saw. The gearbox in the photo is from MHZ. Here is another way to do a simple mount with the same engine...just no gearbox.
Old 04-17-2011, 01:34 PM
  #35
svranger25
Default RE: 72
awesome i'll keep my eye on craigslist,, but back to the hull it has to be done before any engine goes in ,, what epoxy should i use and where to get it, there is not a single rc shop i know of around me
Old 04-18-2011, 05:17 PM
  #36
svranger25
Default RE: 72
opinions on this?
http://www.acehardware.com/product/i...Id=55685358703
Old 04-22-2011, 11:48 AM
  #37
svranger25
Default RE: 72
Anyone?
Old 04-22-2011, 11:56 PM
  #38
martno1fan
martno1fan's Avatar
Default RE: 72
Seal the hull with any good slow setting epoxy,i use west sytems,use an old credit card to spread it on thin and scrape off the exess,repeat this process a cpl more times lightly sanding between coats.
Mart
Old 04-23-2011, 06:42 AM
  #39
svranger25
Default RE: 72
thx for the advice mart,
This is a beginner question so sorr in advance, but was is my next step after the epoxy
Old 04-23-2011, 07:07 AM
  #40
martno1fan
martno1fan's Avatar
Default RE: 72
Its your choice,you can either leave it as is or paint it .
Mart
Old 04-23-2011, 08:31 AM
  #41
svranger25
Default RE: 72
should i glass anything , motor mount areas keel does anywhere need tht
Old 04-23-2011, 10:01 AM
  #42
dwr9
dwr9's Avatar
Default RE: 72
The only place I glass my boats is along the keel on the outside of the bottom, but some people glass the whole outside of the boat. Doug
Old 04-24-2011, 02:52 PM
  #43
svranger25
Default RE: 72
cool, anybody know of good epoxy i can pick up from a local place, i.e. ace hardware, homedepot,
Old 04-28-2011, 11:43 PM
  #44
spede18
spede18's Avatar
Default RE: 72
Lowes sells 8oz loctite 60min epoxy I had good success with this on my 48" build.
http://www.lowes.com/pd_176220-133-1...%3FNtt%3Depoxy
Old 05-07-2011, 08:33 PM
  #45
Driver4r
Default RE: 72
hey i'm just joining this post, i'm thinking of building my own boat and i was wundering if you were going to put any more pictures up
Old 05-08-2011, 07:25 AM
  #46
svranger25
Default RE: 72
ya i will as soon as i get any progress done lol..... this stuff is expensive! i'll see what i can do
Old 05-08-2011, 09:55 AM
  #47
Driver4r
Default RE: 72
thanks
Old 07-06-2011, 09:48 AM
  #48
eastonbighitter
Default RE: 72
opinions on....
@svranger25
are you using the 72 inch mono plans from dwr9? if so how did you manage to get the stringer design from the paper to the ply wood because on the print out that i printed the stringer design of the stringers is only on one peice of paper and im a bit baffeled how to get it from the paper to the actual size on the 1/4 ply wood. And as far as engines go im either gonna try and put a 50cc honda mini bike engine in my boat or im gonna use twin homelite weed wacker engines to power my 72 inch mono and if im correct we are using the same plans. so if you have any tips for putting the hull together it would be very appreticated if you shared them with me and everybody else on this forum wat do you thing for power wise. like if its enough power to move my hull to good speed?
Thanks Jonah
Old 07-06-2011, 08:35 PM
  #49
dwr9
dwr9's Avatar
Default RE: 72
If the stringers are printing that way, the computer is scaling them to fit on one page. The drawings are full size. There should be an option to print them full size. The easiest way to get them printed is to take them to a local print shop. Doug
Old 07-06-2011, 11:05 PM
  #50
martno1fan
martno1fan's Avatar
Default RE: 72
Did you print off all the parts because i think theres one sheet thats just a parts list that prints on one sheet if i remember correctly ?.As Doug says though when printing set the printer to print at 100% and it should print out correctly.
