Wood Mid-West Missile Build
MI
Heres a modded MWM ive been working on.I changed the tub to 4" and stretched it 2" and removed the hood/cowel and made my own full glass one.Heres a few pics,...
MI
RE: Wood Mid-West Missile Build
Hi Scott,..Im trying a few different things. With this first experiment I did this to minimise air drag giving the back of the sponson lift. This is only a theroy.So well see how it pans out.Ill be playing arround with the bottoms also.Its proven that a golf ball will go further with the dimples,so Ill be adding a similar pattern to the ride surfaces to break up the air/water resistance too.Ill be using a stock set of sponsons for a controll to compair.
CA
ORIGINAL: carprigger38
Better yet is using a design already proven over and over again being SHINGLES
They can be single row or made to produce a tunnel between them ... both ways work outstandingly well.
Just suggesting a different approach that may yield better results
