upnorthboater45
upnorthboater45
I cant get water pump on my enforcer with a zenoah engine to push water through it. I've tried 3 different pumps with no sucess.Is the pulse fitting suppose to be on the top or bottom.Mine is on the top which is cause for suspicion.Please enlighten me.Also I have a pro boat water pump,can any of those ports be plugged off,thanks for any help.
My Feedback: (51)
I've never used a Proboat pump,I use Walbro pumps. http://www.bonzisports.com/store/wal...ump-p-109.html Here's the instructions for the Proboat http://www.proboatmodels.com/ProdInf...nstruction.pdf
ON, CANADA
The port should be on top also look for a leak in pulse line and check that the water intakes are not cloged check that cooling cap in not filled with crap as well
