output shaft
CT
RE: output shaft
If you have a Zenoah - you should be using a 1/4" Shaft. Most places carry them. Check these places:
http://www.aeromarinerc.com
http://www.whobbies.com
http://www.rocketcityracing.com/pilot.asp
RE: output shaft
Hey !!! I have the same setup as you G23 with 3/18'' shaft...........but i dont know what prop to use???
Someone has some advice for me? Im thinking in octura props, they are easy to find.........my frined told me about X467 but its a 1/4" shaft prop.........
Please Help me to get the right prop for best speed ( i have a 46" mono )
Thanks in advance !!!!
My Feedback: (21)
RE: output shaft
you can use ANY 1/4 prop on the 3/16 drive ... simply use the adapter included with the prop ( new ones that is )
Which prop ? Theres a LOT to it besides just picking one out . What style hull ? Who makes the hull ? id the engine modded ? If so , by whom ? G-23 is it still air-cooled , or did you water cool it ( add the water jacket to the jug )
Any engine changes what-so-ever ? Add a tuned pipe , or running a canister or ?
What kind of weight is the hull , if its not a known manufacturers ?
Pics of the hardware setup and the hull ( if unknown ) helps a LOT ...
There are MANY variances that regulate which prop would / should work best ( for starts anyway .... there is ALWAYS the trial and error test which usually ends up being the better option )
RE: output shaft
Ok TERBObob i'll try to use a bushing into my X467 and see what happen................
What about the X665, do u think its a great start point too?
Thanks in advance
Thanks in advance
