should I buy this ?
RE: should I buy this ?
You don't need waterproofing for the receiver or any other component. You place them in a water tight "radio box". Spraying waterproofer on the components is likely to void any repair warranties.
Some of us who run for more than a season have radio equipement that is:
A. out of the warrenty period so it doesn't matter
B. buy good stuff to begin with so it doesn't need to go back.
C. rather void a warrenty on a inexpensive electronic part than risk a 3000 boat.
My Feedback: (-1)
dude just use it fix what breaks, thats half the fun of the hobby that boat looks really solid and well set upso u shouldnt have a problem but remember not RTR is truely RTR
MI
Bought my Shockwave 55 new in the box from the hobby shop.
First one was chipped, exchanged it.
Could not get it to run, back to the shop.
2 hours later and 3 phone calls to the warranty place, finally found out it had a choke. The first two tech support guys didn't think it had a choke. Manual did not say it had a choke. Of course, the owner of the hobby shop let the cord fly out of his hand and chip the glass.
My first summer with the boat I:
had 6 trips to the hobby shop (before they didn't want to see me or the boat again)
30-40 calls to the warranty place.
sent the boat into warranty for about 2 weeks (had like 6 problems all at once). Came back with a smashed wind shield
About 8 shipments of replacement parts
at least 8 disappointing trips to the lake
replaced:
kill switch twice ( the radio shack one worked)
muffler 5 times (and had to safety wire the bolts) Oh yea, there is no listing for a replacement muffler-acording to the warranty place
gas tank (when hot muffler fell off for the umpteenth time, it melted into the gas tank)
recoil starter 4 times ( then the warranty place told me to loosen the spark plug for cold starting)
flex shaft 3 times (had to bend stuffing box into alignment and relocate drive dog)
reposition the engine into alignment
re-epoxy the hatch fasteners
true the rudder and strut by milling
reposition radio box and shim steering servo 3/8"
plug leaks in radio box and custom make lid
tape and epoxy throttle linkage at carb mounting bracket (it would slip)
re-secure insulator block and carb to engine
gel coat is spider cracking and engine mounting rail screws are popping the glass on the bottom of the hull
replace fuel lines ( original lines were leaking at connections)
This is only what comes to mind at the moment. "Are you kidding me?" No I'm not kidding[:'(]
My friends were afraid to laugh at me. Thought I made a solid decision buying a high quality expensive product. Found out it is considered a starter boat (RTR- ready to repair). I felt the same way you did when we bought our boats. In less than 1 year I consider it a beater.
I didn't call your boat crap. Here's just the main reason I won't seek out another Pro Boat product.
Just scared me hearing someone buying a second Pro Boat without knowing how the first one treats ya.
From what I've read, the Enforcer Super G is a solid consideration.
replaced:
RTR(Ready-To-Repair), I like that SOunds like you had/are having horrible experiences with that boat of yours, but always remember, he bought the "Super Sport". Ken.
