Best guess on speed with a ProMod Zen?
ON, CANADA
Hey everybody, I am building my first boat and I need some educated guesses.
So far I have a 50" Vern Kilmer Deep-V and I'm running a watercooled Homelite with Warehouse Hobbies wet tuned pipe.
I'm already thinking about more speed so I was looking at the ProMod Zen they over at Warehouse Hobbies(5.5hp)
What kind of speeds would you think I could get with that motor vs the Homelite? Obviously faster but about how many MPH would you guess?
Any other suggestions on cheaper but still fast motors with a clutch?
VA
RE: Best guess on speed with a ProMod Zen?
Not sure which hull you have, I have a 51" cobra Max GT and with a bone stock 260 w/257 carb and tuned pipe I am estimating my speeds at ~45 mph on smooth water and a bit faster on rough water. It is about as fast as I want to go with this hull. If you are looking for more power, consider the new Sikk motor, 5.5hp with a pipe and comes with mounts and throttle linkage for less than the Zen.
TN
I know HP and hull design have alot to do with it. But I have always been amazed on the effect prop mods/selection and set up have on speed.
not sure on speed but look at the hp on these babys at prestwich[link]http://www.prestwich.ndirect.co.uk/zenoahmarineengines.htm[/link] al i can say is a race tuned zen gets 7.2 hp so not sure what mods you refer to at 5 hp.maybe thats a standard mod?.so i guess what im saying is if you want real speed get a race tuned zen or sikk.
ORIGINAL: Davcruz
My Feedback: (12)
SC
ORIGINAL: McFrosty
IL
Homelites do not like to be over revved, I would go with a stock Zen 260, do a bonzi clutch, and run the boat. Later if you want some more HP out of it, send it out to Toxic Al, M&D or CC engines.
You will gain about 2 hp when modded up.
That boat I would use a MW3 prop with a stock 260, and test and tune from there.
