Thunderbolt glitching
FL
My new Thunderbolt has a fairly significant glitching problem - it cuts out intermittently at various locations then will pick back up. The boat was built by Tom at Expresscraft and the antenna is mounted inside the hull. I assume fiberglass does not interrupt the signal, but should I mount the antenna externally ?, or other ideas ?. The failsafe seems to be working properly. Thanks.
FL
RE: Thunderbolt glitching
Do you use the same radio with the other boats and have you tried swapping out receivers with non glitching boats ? Not yet .
Just to humor me - swap out your on off switch (had a friend with a T-bolt with same problem and it was his switch). Will do. Thanks
MA
Yes, try the on/off switch!!!! It took me like 3 months to find it was the on/off switch on the thunderbolt. If you can, try to run the boat on a stand at your house (if you can run water through the engine) and walk away from the boat with the radio. This is what i did many times so i would not have to go after the boat when it died on the pond. Good luck! I feel your pain.
FL
If Tom built the boat, you probably have servo lead extensions on your throttle and/or steering servos . Check the connections on the extensions. Maybe blow them out or spray with corrossion-X or wd40. The extension leads are a common source of the glitch you are getting. Hope this helps
FL
Thanks for the replies. It appears I corrected the problem ..the receiver was just flopping around unprotected in an aluminum radio box. I secured and protected it and seems to be working okay now. I will, however, take the advise from this thread.
