Center of Gravity
CA
Center of Gravity
I have a 41 in Stryker cat with a modded 260. Howevere the motor is a bit too far forward the way I have it. I have gone back and read the posts where the CG should be about 33-34% for this type of hull correct. I will add a couple of pics. I am getting rid of the clutch and doing a few mods but before I did I wanted to hear from you guys who run this hull what the best CG is.
Scott
Scott
CA
RE: Center of Gravity
Thanks Mike,
Yes I will be getting a 100 degree header soon. That is a wrap to center. Sounds good, I will make sure I am around 32-34% because my intent will be to race this.
Scott
Scott
hello doug
i ran a cat on a 34 cg but engine is stock [zen] it runs ok but yesterday i experienced that the prop angle is important .by the way do you run that nice black cat with an open hatch and have no problems ?
MY CAT HAS A PARIS COWL and i had to remove the velocity stack before carb as it stopped due to water in carb.
CA
As of now, I have ran it with the drag style cowl but I jut ordered a turbo cowl due to that exact problem. I dont want to hydrolock my motor. I currently have an X472 on the cat and will try others.
Scott
Scott
