Water inlet fittings for SIKK 27
TN
Does anyone know where to get replacement water inlet/outlet fittings for the SIKK engine? Sean at Oneal bros is trying but no luck yet. Apparently it's a wierd thread (6 mm).
FL
RE: Water inlet fittings for SIKK 27
Paul,
I had a hard time finding that fitting. I ended up using a screw (with a nut on the outside) and simply drilling the middle out to flow water. It worked and looked fine. Pain to do, but that is all I could find.
My Feedback: (51)
Raj, Have you tryed www.clippard.com for fittings?They have fittings in brass and nickel plated that look simular to the ones on the Sikk.
FL
I have not checked there, but thanks for the info. I had to get the boat out in a rush and had to improvise. Thanks again.
XXX
XXX
My Feedback: (51)
Paul, You can find about anything you want at www.thomasnet.com Their site lists a lot of manufacturers and distributers for a variety of items.
TN
No luck on the 2 sites. Great looking fitting on clippard but 10-32 thread[:@] Sean suggested I re tap the hole, but I'm a little squeemish about that.
I may try drilling a screw out as a last resort, But your right definitely sounds like a pain.
Is this what you are looking for? It's a little different with the O-ring in it, but it looks like it will work if you are indeed looking for a 6mm threaded barb.
http://www.anver.com/document/vacuum%20components/vacuum%20cups/Fittings/bm6!.htm
TN
Dude, that looks like the ticket. I didn't see where to order on that page. I'll call them tomorrow. I'll post info.
