need sevo rubber boot ideas!!
I thought of the little rubber boots used on bicycle brake cables, but what do you guys think, is there anything out there that I could buy locally, that could work! I am needing some ideas for the servo box, also where the servo rod exits the stern to feed the rudder to prevent water from leaking in...
I am really worried, I'll flip my hydro on its maden run, and everything will leak.
DA
DA
RE: need sevo rubber boot ideas!!
Aeromarine radio box seals are the way to go! You just drill a hole then use gap filling CA to hold em. They work great! Brian
http://www.rocketcityracing.com/pilo...cific=jonmjnj8 Brian
