Expresscraft SystemCat Build (Rebuild)
My Feedback: (26)
SC
I bought a used Expresscraft System Cat a while ago that I pulled out of storage and I am going to rebuild it. It looked to have twin nitro motors in it. I am going to use twin zenoahs for the build. It came with some Octura hardware so I will use that also. It also came with some old radio gear which I will replace. My experience in RC is with Nitro and Gas RC planes and enjoy flying RC giant scale aerobatic planes and warbirds. Hopefully some of that knowledge will transfer. This build will be for fun running and wave jumping a the lake and not for racing. This site has been great in supplying info and I am sure you will do the same here.
Chris
Chris
My Feedback: (21)
RE: Expresscraft SystemCat Build (Rebuild)
GREAT hulls ! I have done two of them . ( the last one , which has been put on the back burner while I re-do my little pickup - changing over to a Chevy 229 with blower and nos fromthe Mitsubishi engine that comes in the Dodge D50 ) )
Keep us posted on its progress .[8D]
the first one has twin Zen's with QD wtc pipes and the second , twin Sikk/Cy with Hanson pipes
NJ
Grant,
The systems cat is awesome.
I was thinking about doing one in the future. They are beautiful especially if it is done like the scale boat.
My Feedback: (26)
SC
If you have more close up photos of the engine and radio install, please post. It looks like I will have to offset (one farther forward than the other) so they don't touch?
My Feedback: (26)
SC
I took those with my cell phone. I will post some more tomorrow with the deck lid on. I was spending my time today ripping out some huge glubs of expanding foam. I want to clean up the inside of the hull and use "noodles" insted of the spray foam.
My Feedback: (26)
SC
yeeharacing and/or TERBObob,
Do you know where I should set the cg on this boat. I read somewher like 28% from the back??? It looks like from the back of the boat to the spark plug about 16" looks right?? The boat is a little over 59" long.
NJ
Grant,
You probably want to email expresscraft for the actual measurement. Generally cats are 30%-33%,
My 45" Sykeclone is set to 31% which was 13 3/4 from the transom.
By eye it looks good where it is.
call carl at plum krazy rc boats or call expresscraft directly. dean werges knows this hull very well with side by sides. i was looking into runnign side by sides at one time, and was told by carl at plum krazy who talked to dean there a pain to tune.
also raj knows this boat well i beleive. may try to ask him as well.
thats a fast boat with side by sides in it. dean werges got over 75mph with side by side quickdraw 25ht motors in it. with stock zens in it your definately over 50 i think
My Feedback: (26)
SC
Thanks for the e-mail. I will give them a call. I hope it will do 50!! Also looking for suggestions on props. These are standard g-26 zenoahs with Octura running hardware, single rudder mounted between the struts. Any suggestions???
Thanks for the help.
best bet try counter rotating 6717/3 blade propshop props. those motors should push that prop without strain. good all around props also. talk to Dosboata on ebay. his props are the only ones i will use from here on out. there peices of artwork.
My Feedback: (26)
SC
I sent a note to plumb Krazy and they said to have the center of the spark plug 12 1/2" from the inside of the transom. This seems too close to the back of the boat? I was thinking that the engines should be mounted 15 or 16" from the back of the boat? Help!
NY
grant118
I like your build, thats a very nice hull, the paint job is awesome.
I was going to build the Systems, but I went with the MTI with inlines .
I found these pic on Expresscrafts site , may help.
Steve
Steve
NV
ORIGINAL: TERBObob
A+ boats man, Im looking for 1 of them myself!
On a side note..why a 229.. thats old Chevy 3.7l technology... Drop a blown 4.3l in there its got V8 oiling design off the 350sbc, heck it is a 350 with the back 2 cut off!
My Feedback: (26)
SC
Here are some more pics. Trying to get a rough idea of where the cg will fall. Right now I have the port side engine at 18" from the stern and the starbord engine 15 1/2" from the stern. I assume you set the cg with the fuel tanks empty like rc airplanes?
My Feedback: (26)
SC
I have a question about the rudder length. Shown is a photo of the rudder I got with the boat and the longer one that I bought (a little over 1" longer). How long should it be?
