SHE'S ALIVE!!!
SHE'S ALIVE!!!
on the second pull. Ill post some running pics when she takes her maiden run
heres the VID
http://www.firelite-marine.com/
heres the VID
RE: SHE'S ALIVE!!!
You'll get a lot more power out of it if you fit a tuned pipe to it. It will be quieter too, depending which one you fit.
Glenn
Glenn
RE: SHE'S ALIVE!!!
ORIGINAL: firelite_marine
its not connected, havnt put in a drive shaft yet, waitin for my stuffing tube to arrive. very observant
Hi there,
not familiar with that drive system having not seen one. hence my question:- does the drive have a rigid stell shaft between engine and outdrive?
Glenn
OK
RE: SHE'S ALIVE!!!
I'm not that interested in lots a power as much as i am in scale and detail
I think the engine can get trouble with the breathing through the thin tube.
