apache owners
#101
CT
RE: apache owners
Joulesbee,
I saw 2 done with the turbine engine. 1 was found on You tube, the other was on WWW.MHZUSA.COM in the video section. The 1 on you tube was in a miss bud hydroplane thing sounded nice, was fast too. The other was a deep vee on MHZ wasn't as fast I don't think they were really into the throttle, by the performance it looked like just a basic test run, a couple of laps. Where did you get the turbine and how much was it, if you don't mind me asking, maybe interestd for a hydroplane project. Tom
#102
KS
RE: apache owners
Check out a HPR Cat http://www.swissmodelpowerboatteam.ch/ I saw a video of a 92" Cat (2.33) with twin turbines run around...quite a video. I tried to find it quickly this morning, but ran out of time. I believe the same group of modelers built and ran an Unlimited Hydro with a Wren Turbine... Good luck and keep us posted!!!
#103
CT
RE: apache owners
Flogginharvey,
I've been to that site. what great boats. most of those boats are electric, only 1-2 are nitro powered with mhz 2 twin cyclinders, they are fast!!
#105
RE: apache owners
Need some suggestions.....I have the engines to make a single, a twin and a triple. The single and twins are the 26 zenoahs from warehouse hobbies, complete with clutch, tuned pipe and water cooled. I was thinking on using the aeromarine 50" and the 56" for the twins. I have yet to find a hull for the triple....any big ones out there, the triple is also 26 zen, only this will be air cooled and clutch. I would like some assistance on set up....is the 30% rule in effect for these hulls....been quite a while since I built one. I have 6 struts and rudders, but am thinking for the single and twin, to use kanellos drive c-rotating on the twin.......any sugestions????
#106
RE: apache owners
use this link and copy and paste the web address in translate web page. and select your translation german to english
http://babelfish.altavista.com/
#108
CT
RE: apache owners
dr drip, if you look on page 4, 3/4 way down look for Apache57stryker43 post. I had the same question, and he answered it great for me, i am waiting for my engines to come. if you scroll through page 4 I have the black Apache its 84" custom paint. Boat was purchased through Bonzi. But try to find it through someone else I am not happy with the company. Also if your looking to go bigger www.MHZUSA.com has a 96" Fountain. That should be big enough for the triple. That will proably be my next boat, I want to do twin 70cc from Quickdraw. Tom
#110
CT
RE: apache owners
Any one interested in looking at nice drives check out www.wd200-modellbau.de click on Antriebe, then click on Lenkbarer Antrieb. Tom
#113
RE: apache owners
ORIGINAL: nieto1124
That parts on that shaft are from the "grainer" or "Macmaster" catalogs. its custom built. dont think you really want it anyways. they look pretty but the u-joints cant handle the rpms. [&o]
The uni's and slip joint came from - http://www.sdp-si.com and ran around $65. Lasted Phil around 10 minutes of gentle running.
Then she went to a flex cable
#115
RE: apache owners
Well i worked on the Apache Warpath to dress up the inside of the hull. I used Duplicolor's truck bed coating that you can buy in a spray can. It works really well and it looks sweet. Here are some pictures.
JT
JT
#119
RE: apache owners
I thought about building a bigger one, 70'' expresscraft with a bit more power but i am going to hold on to my 56'' Aeromarine for now. I still have to reach my goal of 60mph with it. Thanks for the kind word's guys. Keep the Apache's comming!
JT
JT
#121
RE: apache owners
Tom,
its the newest 35cc Quickdraw that has the steel crank and is in stock form. So far the boat has ran a best speed of 57.1 or 57.2, cant remember. Some prop changes, carb adjustments and the right water and it should be in the 60's.
JT
JT
#125
RE: apache owners
Just want to share pictures of a friends Apache, the deck is cutom made from wood
http://i55.photobucket.com/albums/g1...8/DSC_6048.jpg
http://i55.photobucket.com/albums/g1...o/IMG_6687.jpg
http://i55.photobucket.com/albums/g1...casCruiser.jpg
http://i55.photobucket.com/albums/g1...hefullbore.jpg
