Engine problem
Engine problem
I have a McColloch MT310X 32cc
The problem i have is that the pullstart needs fixing and i cant remove the clutch
Anyone no how to do it.
CT
RE: Engine problem
Do you have a piston stop tool ? If not you can use small string and put a lot of it down the spark plug hole, enough to stop the piston when turned over,with about a 6" pieace sticking out from the spark plug hole and try to turn the clutch off. then pull out the string. It should work.
RE: Engine problem
ORIGINAL: Wet-N-Wild
RE: Engine problem
yep theres a hex screw up the hole where the flexy cable gos undo that and the bell will come off then the clutch unscrews off to crank i think its a left hand thred so just check that
hope that helps
hope that helps
