manta ray is a slug
ON, CANADA
manta ray is a slug
heres the scoop, i have a AM 48 pro that is a rocket, just bought a manta ray, put in a stock 26 with a several dif props, 270 prather, slug, 7016 slug, prather 275 slug, honestly why does everyone say this boat is good, i trim up and down, tabs and drive, differnt props, lean rich, left right, up and down, green and blue and this thing runs wetter that a submarine.......is this boat even made to get up and go , my other boat isnt even n the water most of the time, but this thing is a sherman tank, real upset to say the least!!!! when i actually get a fast prop on it it gets up and then the nose is like an anchor!!!
PS for sale!!!
PS for sale!!!
ON, CANADA
RE: manta ray is a slug
its got th labels and tony confirmed iot...ita real...can believe it....just in awe right now....this boat is slower than my friend v24 design, its just not right...lol
Have you checked for rockers and hooks in the hull?,especially on the last 1/3rd of the hull at the transom,check the ride surface using a straight edge if you see light under it you have hooks if it rocks you have rockers both of which will make for a poor running boat.If everything looks fine then its maybe the setup how about some pics.
Mart
Mart
ON, CANADA
got no pics right now but i dotn thin k there is much i am doing that isnt normal i have the drive stright (this wasd the fastest) trim tabs up and out of the way,,,,
My Feedback: (14)
I can just about assure you there is nothing wrong with the hull. start from scratch check everything again. this hull is very nice. you must have missed something. you running a clutch?
here is one running.
http://www.youtube.com/watch?v=a-bcsNpf1KU
Check the bottom with a straight edge, and pay attention to the trailing edge corner. Where the transom meets the bottom needs to be a sharp 90* corner, any roundness will suck the backend down.
ORIGINAL: nieto1124
ON, CANADA
this what i am saying my other boat does 51 MPH and its uts, this thing is like a slug, i think the video is way to wet as well..the boat looks like an anchor...lol there has got to be a way to get this thing up and out of the water.....
Warehouse Hobbies boats are know to have rockers in the hulls so I see why you were asked that. This is one reason why they can't take a highly modded motor.
Got trim tabs? Raise them up.
Carb, 2-1/4 out on low, 1 turn out on high. See if that wakes it up or not.
Keep in mind that you've got a big heavy boat there so it's not going to be a rocket. If you want fast then get a racing hull, not a sport boat. It's made for playing hard with as it will take a beating.
When was the last time that you saw a WHH boat in the winners circle at any boat race or for that matter, in the top three? You might see their new one, the Silex but not now.
ON, CANADA
i know but i had a shockwave and its atleast 20 km faster than this slug...my trim tabs are all the way up!!!! next i am going to remove them...
maybe we should run the BBQ and yellow banana into each other and be done with our problems with these boats and buy something else
that would be sweet to see
ORIGINAL: cyclops1970
Banned
cuz that boat runs with a wet pipe system, double rudders and a clutch, can't expect it to run like a missle unless you kick them out, check its running vid as tony posted it on his website, the boat is run for fun.
http://69.49.183.35/ProductDetails.a...tCode=MantaRay
ON, CANADA
my 48 pro runs a wet pipe and its a rocket......this boat is just a slug thats that....
<Mod edit - removed text>
PA
Ok guys here is what I can say after spending a summer with my old Revenge boat that is posted all over here and I will post more pics here with this post.
I talked to Tony at length about what to do when this boat seems to run wet.
He told me that this boat was designed to run in chop.
If you are running the boat on a glassy pond then you bought the wrong boat.
The Team pro would have been better but then again they are not rockets like some of these other 40+ inch boats that are out there.
The new Silex should run with the best of them but time will tell that story.
Also if you are running a clutch that will slow that boat down also.
Another thing to remember is that the boat is almost 10 inches longer then the race boat that you are used to.
The bigger the boat the more engine it takes to get it going and the Manta Ray needs a Mod motor that makes torque to get it ripping and about a 2 inch chop or some wake from another boat.
Try the boat on some big water with some chop and you will love it.
If you are not satisfied with it call Tony and tell him what you are experiencing he might take it on trade for the Team pro.
I like the Manta Ray cause it is extremely stable on all kinds of water and makes an awesome all around basher boat!
Here is my old Enforcer Revenege (Red Rocket)
I have a Manta Ray and I love it. Definitely a big wave boat. You bought a boat that was not intended for the purpose you want to run it. This boat is not for racing. It is a 40-45 mph big wave boat. It is also setup for new boaters to have fun with. Take more time and bring it out on bigger water.
I knew a guy that had one that had same problem as your boat it was a hook in the hull bloody thing was so wet running could only see the spray not the boat it too was genuine article which was the biggest let down
PA
Call Tony tell him the problems that you are having maybe he can give some light on this subject.
I know the one that I run with in the summer time likes a bit of chop to get alot of speed out of it.
On a Pond or calm water it is NOT so great kinda slow!
Tony has been building boats for a long time. The boat that you are running is not a speed demon by any means. Most of his boats run in the mid forties at best. The extra lenth, and weight are big contributing factors into this. What you may want to consider to get more performance from it is: First, get the motor modded, Tony sells modded jugs that will allow the motor to breath better and make more horsepower. Second, if running a "wet Pipe" ditch it and go to a dry pipe system, water going thru the pipe will rob you of power as well. Third, contact one of the guys that do props, Chris (dasboater) Bob Austin (prop works) and get them to make a prop for you You can also loose the left rudder and that should make a difference in speed as well. Unless you are making a lot of left turns, it really is not nessessary, boat will still turn left with only the one rudder, but will have less drag.
hope this helps, John Crouch
Ron you better watch out. They are coming and coming strong[>:]. When was the last time you saw one. The new silex pro is an excellent boat. I am getting speeds at 65mph and taking corners with out letting off the trottle So don,t tell me that Wharehouse hobbies does not know how to build a good boat. My last boat was a proboat miss elam 1/8. It made a great boat anchor. My sons $250 superV27 out ran it.
