My Dilema
My Dilema
So my PB BJ55 hull is damaged and I don't feel that it is worth repairing.
Problem is the hull became damaged while my new CC Powermaster 2" band was sitting at Customs.
So now I have a CC engine and pipe and need a hull to fit it in.
The hull I would like to use has very little freeboard in comparrison and so it needs a pipe with 25 degree drop from the exhaust port.
The CC system uses 1" OD pipe and they don't have any drop pipes available that I'm aware of.
What I need is a hull that will allow me to use this engine/mounts/pipe combination and is esthitically pleasing.
I like the CT03 or Mystic 5000 but both are a little on the big side and require dual engines to drive them properly.
Ideally the hull would be >45" in length but <65".
Ideas?
Ideas?
RE: My Dilema
I like catamarans, deep V would be next best but I have a tough time looking at them. Thunderboats, F1 tunnels, hydros and riggers might appeal to some but for me just the big cats!
Give my a mystic 5000 with twin turbines and I'd go away happy.
CA
RE: My Dilema
Couldn't you return/exchange the 1" header & pipe combo for a 7/8" Powermaster combo? I'm sure it would cost ya with shipping and all but at least you would have more header options with that setup.
Did you look at the Aeromarine's Avenger or Conquest? They are a little smaller than your looking for but not by much. How about Expresscraft MTI? Not sure your setup would push it. Seems like most guys are running QD's or an inline in that hull but I could be wrong. It's a good lookin boat though.
RE: My Dilema
ORIGINAL: jacob711
nemesis cat?
surely you could modify the header if need be, cut and shut it
nemesis cat?
RE: My Dilema
ORIGINAL: rcguy1411
go to plum krazy boat they have a lot of cats in the 50'' to 60'' range i like the 60 '' mti cat myself it will be my next project
If I were going single engine the Nemisis seems to be my favourite. For twins the CT03 on a budget Mystic 5000 if the wifes busy looking the other way!
That said I don't think my pipe would work in either.
RE: My Dilema
ORIGINAL: illiniboater
Couldn't you return/exchange the 1'' header & pipe combo for a 7/8'' Powermaster combo? I'm sure it would cost ya with shipping and all but at least you would have more header options with that setup.
I guess I'll give them a call Monday and plead my case. With any luck I can either return it or best case obtain a custom header. Doubtful on the custom part though as I approached them about a custom engine mount and was turned down.
