motor mounts
IL
RE: motor mounts
Nevermind I looked it up on dremel.com and found the attachment you were talking about and then found it at my local Home Depot. Thanks for the help, much appreciated.
RE: motor mounts
I got mine at Sears. Dremel has an egg/teardropped shaped bit that works well for making the hole. They used to have an oversized (over 1/8") drill set but I haven't seen it in a long time.
http://www.dremel.com/en-us/Attachme...l.aspx?pid=124
RE: motor mounts
I use a modified drill bit. Shortened to about 1.5" and re-sharpened in my DrillDoctor. Works perfectly when used with my 90 degree drill.
www.rcuniverse.com/forum/fb.asp
RE: motor mounts
My method, although a bit "sheddy", is to use a small metal TEK screw in a small socket ratchet driver, and apply pressure whilst turning, this may sound a bit rough, but it works fine when you live outback and the mod cons are hard to get hold of..just my 2 cents worth..thanks Scoot
