4 bearing zenoah
4 bearing zenoah
well guys iv been playin around with building my own 4 bearing zenoah (not a new idea )
but my one is a stock parts set up
its done with two rear cases (the small ones)
a quickdraw timing plate and some match porting quite easy to do ill post some pics later
THIS IS NOT A SLAM 260
cheers
cheers
RE: 4 bearing zenoah
Now that's interesting, Can not see why it wont work. Can you buy the parts loos other wise you have to use 2 motors to build 1. $$$$???
How far is your F1?
Cobus
How far is your F1?
Cobus
buy one g260 and a spare crank case and thats most of your parts
the tunnel is looking good ill get some pics this weekend
cheers
cheers
iv ran this motor in my conquest with no issues at all and it looks good
like i said iv seen the slam and iv done soom research and doing it like this you can use quick relese mounts
cheers
cheers
good going there mate. dosent look like a slam to me(there powder coated,red and blue arent thay) .
looks like a zenoah you could call it.the back to back.case motor....
if it works runn it... enny way who cares if it looks like a slam thay only used zenoah parts enny ways. and called them slam
and you have used zenoah and qd parts that you had ..great work good to see people trying difrent idears out. ill be making one my self if you dont mind.. hehe.....
CA
My most recent build ....
RCMK S-254 cases running 4 bearings with stock coil tower machined off, M-boat timing plate replacement, J&G billet cylinder kit.
Internals are a rcmk crank & piston, Zenoah flywheel & electronics.
Sweet engine !!
Sweet engine !!
nice work im goin to get a new gen rcmk cyl as soon as i can
iv got another one in the works im thinking of getting the cranks case polished its for am shelf queen im goung to be building
cheers
cheers
