zenoah/sikk/model gas engine... v2 twin?
ok lets say im building doug's 72" mono(which i plan on doing but not currently).is it possible to fit a v twin zenoah(not inline zenoah)(like this->[link=http://www.youtube.com/watch?v=13oPgkWvrb8&feature=PlayList&p=5962C8D41F63B571&playnext=1&playnext_from=PL&index=27]v2 twin[/link])and if its possible,what prop and hardware shall i use?thanks
RE: zenoah/sikk/model gas engine... v2 twin?
Before worrying about fitting it (which you should be able to without much issue) I would be more concerned about where you will be sourcing this V twin motor. My understanding is that the one in the video is a 1 off custom build. I know MHZ were building a V set up for sikk motors but cringe at the thought of what that may cost.
yes i noticed that was a custom build and im willing to do it myself no probs,anyway seeing it will fit , what prop and hardware shall i use? thanks
getting hardware and prop - least of your problems. Getting the motor together and running reliably would be my focus right now.
Leave prop purchase till near the end - any changes you may make in the mean time will make your prop selection redundant. For 2 zenoahs stock ungeared/unoverdriven I would think a prop like the 8015/3 propshop or similar would be a good choice (surface driven). If you overdrive then that choice would certainly change.
For hardware - Take your pick - theres tons of good options out there. If your considering doing the work to assemble the motors in a V then you may also consider building your own strut and rudder.
hi ,no i dont think i will do my own hardware,i was thinking more of something like [link=http://cgi.ebay.com/rudder-extend-stinger-1-4-cable-trim-tab-turn-fin-combo_W0QQitemZ140313460928QQcmdZViewItemQQptZRadi o_Control_Parts_Accessories?hash=item20ab5580c0&_trksid=p4634.c0.m14.l1262]this!![/link] thanks
ok lets say i dont buy that hardware,and buy some other kind of hardware.what do you suggest?i would like it to be a combo ie: stinger rudder shaft etc all togheter and not bought separetly so i dont have the hasel of forgetting somthing lol
have a look on this site drop them an email they do complete packages also.
http://www.topsecretboats.com/home
the other products are ok but if your running in saltwater the needle bearings in the stinger drive
will not last long so i've been told..
yes without a doubt you must also flush the cooling system with fresh water
to flush out the salt
This engine is called a v2 but they are 2 separate engineĀ“s and not an v2 carter like a harley does have.
