Easy Vee Pics!
AL
Easy Vee Pics!
Post your easy vee pics here. I just wanna see some especially if you got a nice paint job because I'm trying to get some ideas of a design. If you got a different boat with a nice paitn job feel free to post it as well
RE: Easy Vee Pics!
Hi m8, doing a search in the forum will get you lots of pics, Heres my build and the paint job at the end.
http://www.rcuniverse.com/forum/m_87...tm.htm#8843090
Still tweaking her but she's a great boat to run..
Henry.
Henry.
AL
RE: Easy Vee Pics!
nice thanks. still working out engine mount problem.. this weekend I plan on mounting engine shaft tube stinger... etc hopefully will get some pictures
LA
RE: Easy Vee Pics!
Hi Stacked well I just put my Radio box together tonight it looks a little Rough because the box that came with the easy V was too small for the Servos and setup that I plan to use so I had to improvise and make the Box a bit Deeper then the tops did not fit right. but A little Plastic wood some Elbow Grease and a lot of Paint will make it look good. I have not started to get mine ready to paint yet but it will be soon. here are some pics.
RE: Easy Vee Pics!
stackeddeck
A couple of pics too your question in my pm,,, I had a small length of S/S tubing that my 5/16 tube went in nice a snug so I used that to glue to the hull and slid my 5/16 tube through that so will be easier to replace when necessary, And never have any problems with water in the boat the two autobailers take care of that, just have to make sure your boat when its finished is always clean on the inside so no rubbish can block the bailers..
Henry..
Henry..
