DaVette SK shallow v
TN
RE: DaVette SK shallow v
Looks great Dana. Is the bottom of that one similar to the old flat bottom you used to make before you converted everything to runner bottoms on the drag boats? I loved the way mine would slide in the turns
Beautiful place to run. Too bad your 2500 miles away[]
No , this design has more of a shallow v and I gave it some small spray rails on the chines so it doesn't slide in the corners . This is a much faster design but it doesn't like rough water .
