Auto Bailer???
FL
Auto Bailer???
should i put some Auto Bailer on my sprint cat???? do yall guys have them on ur cat? how dose it work?? cuz one of my buddy have them on his cat and he get more water then not having them..
MD
RE: Auto Bailer???
i have 2 in my nemesis cat and 1 in my fountain boat. i like them, they work great. i guess the idea is to maintain them, as in keeping crap out of them. so they can work right
RE: Auto Bailer???
They are better known by their other name, autosinkers. They might drain some while the boat is underway but when the boat is stalled they usually introduce water at close to the rate of open holes, possibly faster as ball usually pumps back and forth no matter the orientation to level and fills the boat with water.
NY
RE: Auto Bailer???
ORIGINAL: nothinbetr2do
I have used them on many builds.
You can also drill a small hole at the top of the transom on one side.
Lift the bow straight up to drain water !
Steve
RE: Auto Bailer???
I have them in all my Boats, And as said you must keep the inside of your Boat clean so no rubbish can get around the Bailer as they will not work, I have found the aeromarine ones are the best as they have a wire mess to help stop rubbish getting in them, But still before every run make sure all is clean and you won't have any problems.
Henry.
Henry.
