super g
FL
super g
i havent run my boat in a while it cranked but was way off tune.. have a good idle but no high and also have oil mixture leaking where my pipe is connected.. still a bit of a newbie any advice???
RE: super g
sounds like your carb is gummed up or gaskets leaking, give the carb a good clean and replace the exhaust gasket. Exhaust gasket alone won't stp it from going to high though.
NJ
RE: super g
Also check the diaphram in the carb. They sometimes become hard or not as flexable as when new. Remove the 4 small screws & the plate will come off to check it. If you have a inline fuel filter, check that too.
pyro1
pyro1
