Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
GAS F1 INBOARD TUNNEL HULLS
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 04-07-2012, 01:57 PM
  #351
HendricX
HendricX's Avatar
Default RE: GAS F1 INBOARD TUNNEL HULLS
Are you talking about the Dutch-made Synthar .. made by John Vianen ?
Can't remember ever seen one as an inboard .
If you have one .. I would like some pictures > hendricx50 [at} hotmail [dot] com
Old 04-08-2012, 04:17 AM
  #352
Eddy de Vries
Eddy de Vries's Avatar
ID:	1748003   Click image for larger version
Old 04-08-2012, 03:32 PM
  #353
HendricX
HendricX's Avatar
Thanks Ed .... Ha ha .. must have had sand in my eyes at last F1 meeting.
Old 04-24-2012, 05:56 AM
  #354
Stuart Sale
We are fitting a new K30R into the newly modified Alpha F1 should be good
Old 05-13-2012, 03:27 AM
  #355
rfg racing
Hi Fella's gone a bit quite here!!!!
so i thought i might try and liven things up a little....
wanted to see if my rcmk twin would fit into my tunnel????
twin engine is fitted with an over drive gearbox ..three sets of ratio's to test!!
weekend of playing in shed and its ready for first run, but will have to wait a few weeks
before it can get wet..
Old 05-13-2012, 03:33 AM
  #356
rfg racing
sorry having trouble up loading photos
ID:	1762130   Click image for larger version
ID:	1762131   Click image for larger version
ID:	1762132   Click image for larger version
ID:	1762133   Click image for larger version
ID:	1762134   Click image for larger version
Old 05-15-2012, 04:32 PM
  #357
F1TUNNEL
Looking good Frank!! What rudder and strut are you using? I need to get some for mine at some point and put it together.
Cheers,
Dion.
Old 06-11-2012, 12:18 AM
  #358
trickeyf12
Hi guys.
I am geting back into  gas F1 boating.  I have a OB hull that i run some times,and have just brought two hulls to build as inboard. One for me and one for my 12 year old son.  I believe that the hulls are modified DPI huls. Both hulls have been run as inboard and then changed to OB.
Both hulls have had the transoms changed for the out boards.
I have removed these and am thinking do I make it a straight transom, or extend the transom past the rear of the sponsons?
what are peoples recomondations? and how far would I extend.
Thanks in advance.
Cheers Shane
Old 06-13-2012, 01:13 AM
  #359
trickeyf12
Here is what I am working on. Any suggestions?
Cheers.
Old 06-13-2012, 04:07 AM
  #360
Eddy de Vries
ORIGINAL: trickeyf12
Cheers.
Herewith some pics of how I did it with my glassfiber copy.
As you can see I had to reinforce both the transom and the bulkhead (for outboard use) afterwards.
According to Jerry Dunlap, one of the designers, the DPI is not suitable for the gas power though, see post #4 [link=http://www.intlwaters.com/index.php?showtopic=51567&st=0&p=477879&#entry477879]here[/link]
quote - Having been somewhat involved with the DPI 1/4 Scale Tunnel(as well as other DPI designs), I'd recommend looking somewhere else "for another boat to hang a gas OB on." The boat traps way too much air. - unquote
Rgds, Eddy
ID:	1771669   Click image for larger version
ID:	1771670   Click image for larger version
Old 06-13-2012, 10:38 AM
  #361
penguinsurfboards
Cheers.  Yes Ship me that Black Boat !!!!!!!!!!!!!!
Old 06-13-2012, 12:18 PM
  #362
trickeyf12
Thanks Eddy.
Thats the type of advise I am lookng for.
The red and blue hulls will be inboard so mabey easier to keep on the water?
Is there any benifit to extending the hull for inboard power? They were both inset to where you see I have cut them to.
Penguinsurfboards, Let we think about that .............. arh No LOL
Old 06-14-2012, 12:25 AM
  #363
Eddy de Vries
Main reason I did it was to have a more scale look.
Another advantage was that an offset transom brings the prop further back and thus makes the prop lift momentum bigger.
I also fiigured that shortening the boat afterwards would be easier than lengthening ?
Rgds, Eddy
Old 06-14-2012, 12:58 AM
  #364
trickeyf12
I also like the scale look.
Just thinking, if these hulls trap to much ai,r do they need lift further to the rear, or is that going to make the
problem worse?
Old 06-14-2012, 06:22 AM
  #365
Eddy de Vries
Once mine is near topend the dynamical CG seems to be OK.
Only problem is getting there, especially with a too fast accelerating propeller.
My experience (with an outboard) is that a 6717/3 seems to be big enough to prevent most porpoising and thus blowing over during acceleration.
Old 06-15-2012, 02:08 AM
  #366
trickeyf12
Thanks for the advise Eddy.
Old 06-22-2012, 04:17 PM
  #367
BenniRidds
hey there, im new to the hobby and currently runnig a thunderboat, but from a young teenager iv have been kicking arond with my mate who run the real f1 tunnels here in new zealand and we were searching for ur f1 tunnel popped u, just wantig 2 know what brand the hull is and where u can purchse one, as we are looking at setting an f1 tunnel up?
Old 06-23-2012, 10:04 AM
  #368
HendricX
HendricX's Avatar
ORIGINAL: BenniRidds
we were searching for a f1 tunnel
The Dutch made Synthar .. will be extremely costly to send to NZ.
Better try to get a hold on to Mark Jordon .. forget if he's Aussy or NZ.
Old 06-23-2012, 02:18 PM
  #369
trickeyf12
Hi the black outboard hull was made by grh hobbys but the owner has pased on and the moulds seem to have been pased around a lot since
And I don't know who has them now sorry. I don't think it's the best hull anyway. The two I am working on now I got off trade me.
The ones Mark jorden builds look good, I believe they are around $750.00 aus. I was thinking about them myself untill these two came up
On tm.
Cheers
Old 06-24-2012, 12:47 AM
  #370
F1roddo
Mark Jordan hulls are very good and well built, and I am currently running one of them and another club member also has one too.
We are both very happy with them and mine is getting better and better each time out. I have also found that I keep coming back to a 6717/3 prop, as its the best so far.
Cheers
Chris
Old 06-24-2012, 02:13 AM
  #371
YPC
YPC's Avatar
Hi Benni
We build a GAS F1 INBOARD - US $700 (including the shipping to Aus) - colour deck - white hull.
It has been successfully tested/raced with various drive units - from the standard inline rudder system - standard strut and rudder - our Camber out drive.
Supplied - bonded and trimmed - transom/sponson reinforcement fitted - flotation installed - mounting brackets supplied.
[youtube]http://www.youtube.com/watch?v=2kJhGrm8xcc&feature=plcp[/youtube]
We only still manufacture our ENIGMA CAMBER OUTBOARD DRIVE - ( No longer the Inboard drive)
Drop me a mail should you need more info
Regards
Dominic
Youngz Performance Craft
[email protected]
ID:	1775159   Click image for larger version
ID:	1775160   Click image for larger version
ID:	1775161   Click image for larger version
ID:	1775162   Click image for larger version
ID:	1775163   Click image for larger version
ID:	1775164   Click image for larger version
ID:	1775165   Click image for larger version
ID:	1775167   Click image for larger version
ID:	1775168   Click image for larger version
ID:	1775169   Click image for larger version
Old 06-25-2012, 12:09 AM
  #372
trickeyf12
Hi Dominic  I was going to contact you about your inboard drives,but see that you are not building them?
What is your recomdation for a strut and rudder set up?
Cheers Shane.
Old 07-25-2012, 12:44 PM
  #373
8thscale
Guys,
I'm doing a lot of reading, and sometimes a little skimming to try and find where to buy an inboard hull. Am I missing something, somewhere? I like Dominic's Hulls, and Latif's (Body Guard) Hulls, but I can't find anything else about purchasing one. I tried youngz performance craft, but I only see info on an outboard leg.
I would be interested in a used hull, that is built for an inboard, that may be in need of some re-finishing.
I'm located in California, so that may be an issue getting something from out of the U.S.
I actually thought about making a foam plug, but really don't want to invest that much time into it.
Any help would be appreciated.
Steve
Old 07-26-2012, 12:31 AM
  #374
F1TUNNEL
Hi Steve,
Try pm'ing both YPC or BODY GUARD, you will have much better luck that way. Dom should have hulls already made and chat to him about the inboard leg. Not sure what the shipping will be like price wise but they do ship over seas. The YPC site has not been updated in a long time and I always forget to ask Dom about this. I have read good reviews that Dom sent me about his inboard leg- there are a few in the States now being run. There are a couple of companies in the states making gas hulls, but they are for OB as far as I know. I too am setting up an inboard on the side-not my main focus at the moment but should be fun when done. The inboards throw up a bigger rooster tail than the outboards which does it for me. One day I will build or buy a rigger for the ultimate rooster tail!!
All the best with your build,
Regards,
Dion.
Old 07-26-2012, 07:05 AM
  #375
8thscale
Dion,
Thanks for the reply. I wonder if you or anyone else has had experience taking an OB tunnel and converting it to inboard. I see the Zipplits Illusion Tunnel is set up for OB. Besides re-working the inside of the hull (by adding stringers, etc..) I wonder if this is a viable endeavor, or should I just try and find a purpose built inboard.
Thanks again for the help.
-Steve
