Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Dumas Hot Shot Sprint 3.5 Tunnel Hull Build
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 10-04-2010, 05:52 PM
mgcrimson
mgcrimson's Avatar
Default Dumas Hot Shot Sprint 3.5 Tunnel Hull Build
I'm fixing to start building the Dumas Hot Shot Sprint 3.5 Tunnel Hull. This will not be a fast build as I only have time on weekends to work on the boat. I will be tracking my progress and posting pics as well. Any hints and tips will be well appreciated.
Old 10-04-2010, 06:17 PM
wave waker
Default RE: Dumas Hot Shot Sprint 3.5 Tunnel Hull Build
ORIGINAL: mgcrimson
if you search more maybe you can dig my thread regarding this boat, i'm having so much fun of this boat,,,,
enjoy the building[sm=thumbup.gif]
ww
Old 10-04-2010, 07:29 PM
mgcrimson
mgcrimson's Avatar
The 1st boat I ever built was the Dumas Hot Shot Sprint 7.5 which was over 10 years ago. I had started theABS hot shot 3.5 but never finished it. I used a paint scheme very similar to the one that Maus showcased on one of their sport hydros. I got into racing rc cars and ended up trading themfor some car stuff. I new one of these days I would regret itand man do I ever. Still know the guy that has the 3.5 and i'm in the process of trying to get it back.
ID:	1511073   Click image for larger version
Curby76 (08-30-2021)
Old 10-04-2010, 08:11 PM
toyotatruckin
I sold off all my RC some time back (SLOWLY am getting going again) and the dumas 3.5 I was modifying went before I totally finished it up, plugged off the back section dropped the front (radio box) section way down, and mounted a VS1 cowling on it, still had some stuff I was going to do to it BUT sold so didnt, here are some pics of where it was. also cut the cowling down so it wasnt as tall off the deck
Old 10-04-2010, 09:12 PM
ob nut
ob nut's Avatar
Which of the Hot Shot Sprints do you have? ABS or Wood?
Old 10-05-2010, 05:45 PM
mgcrimson
mgcrimson's Avatar
The one I'm building now isthe wood kit. The black 7.5 that I built several years ago was wooden also. The red 3.5 was ABS.
Old 10-05-2010, 09:51 PM
ob nut
ob nut's Avatar
My last wood Sprint build was done WOF style. Once the main frame has been glued up, glue in foam within all the open spaces: (spoons and center section). Sand down the foam and then start to lay down the sheeting. For gluing the foam to wood / wood to foam, use Gorilla glue. Stuff will "foam" up and fill in all the gaps. The plus side to this is that the harden glue is easy to sand, unlike epoxy. This process will speed up the build since all those 1/4" stringers won't need to be glued in.
Old 10-09-2010, 09:44 PM
mgcrimson
mgcrimson's Avatar
So far I've assembled the jig, glued the hull framework to the tunnel top, installed the transom doubler and sponson points.
ID:	1513614   Click image for larger version
ID:	1513615   Click image for larger version
ID:	1513616   Click image for larger version
Old 10-10-2010, 12:56 PM
matt420
Lookin good man, i remember racin a hot shot 16 years ago, after a sponson mod it did pretty good with a stock kaboom!!!!
Old 10-16-2010, 04:58 PM
mgcrimson
mgcrimson's Avatar
Got the stringers glued in. Next I will start to skin the hull. So far no problems with the build. Simple and straight forward.
ID:	1517820   Click image for larger version
Old 11-10-2010, 07:23 PM
mgcrimson
mgcrimson's Avatar
Got the bottom of the hull sheeted. I left a small overhang on the rear of the sponson bottom. Next is laying the seeting down on the top of the sponsons.
Old 11-10-2010, 09:26 PM
Jerry Dunlap
I recommend coating the interior of the hull with epoxy prior to attaching the top sheeting.
JD
Old 11-11-2010, 05:24 PM
mgcrimson
mgcrimson's Avatar
Forgot all about that. Thanks for reminding me.Havn't done anything to it yet so I'll try to get it sealed this weekend before the top sheeting goes down.
Old 11-11-2010, 05:27 PM
AussieOutboard
ORIGINAL: Jerry Dunlap
JD
Hi Jerry, I am building the Hot Shot 7.5 at present. Would layering the inside of the sponsons with resin affect the flexibility of the hull? It wouldnt be prone to cracking at all?
P.S nice build thread here too...I've subcribed ;-)
Old 11-11-2010, 08:27 PM
Jerry Dunlap
ORIGINAL: AussieOutboard
JD
When I coat the interior of a wood hull, I use a heat gun to thin the epoxy/fiberglass resin. Then brush the thinned material. Your don't need a heavy coating to seal the wood. Hull flexibility really isn't an issue. Thinned material shouldn't crack.
JD
Old 11-11-2010, 08:35 PM
AussieOutboard
JD
JD
Thanks JD. I will add this int my project Just so happens I have a heat gun. Thanks for the tip.
Old 11-12-2010, 02:38 PM
TCHedOff
Jerry,
How did you coat the exterior of the tunnel you built for Rod? Was than just 2 coats of epoxy applied as you describe or did you use and auto clear coat. The finish was fantastic.
Old 11-12-2010, 05:55 PM
mgcrimson
mgcrimson's Avatar
How do you feel about adding alcohol to thin the epoxy. I've done this with another boat that I built a long time ago to seal it with epoxy.
Old 11-12-2010, 07:17 PM
Jerry Dunlap
ORIGINAL: TCHedOff
Jerry,
Rod finished the boat, I just sent it to him with West System Epoxy used for sealing the wood.
JD
Old 11-12-2010, 07:19 PM
Jerry Dunlap
ORIGINAL: mgcrimson
Alcohol will thin the epoxy, I just prefer to use a little heat.
JD
Old 11-12-2010, 08:35 PM
Hydro Junkie
Hydro Junkie's Avatar
Depending on which epoxy you use, alcohol can prevent the epoxy from curing properly. Just something to think about
Old 11-12-2010, 09:59 PM
toyotatruckin
Ill agree with jerry on the heat and HJ on what he said, I dont add anything to thin my epoxies heat and or buy the correct epoxy
Old 11-13-2010, 06:25 PM
mgcrimson
mgcrimson's Avatar
Where can you get the West System Epoxy at?
Old 04-09-2011, 06:42 PM
mgcrimson
mgcrimson's Avatar
I know its been a while but I finally got the hull skinned. I will be sealing the hull soon and then will start adding the hardware. Stay tuned!
ID:	1591633   Click image for larger version
ID:	1591634   Click image for larger version
ID:	1591635   Click image for larger version
ID:	1591636   Click image for larger version
Old 04-10-2011, 03:50 PM
mgcrimson
mgcrimson's Avatar
Hull is sealed
ID:	1591987   Click image for larger version
