Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 Well cooling problem solved >
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 12-20-2010 | 02:19 PM
Default Well cooling problem solved
i called TH and they're gonna mail me one.He said it'll be mailed in about 4 days,so i figure 8 days from now.You know i think he thought i was lying,just the way he sounded,oh well.I know i wasn't.
Old 12-22-2010 | 04:13 PM
ob nut's Avatar
Default RE: Well cooling problem solved
I ordered a Deuce from TH last week. Got a prop for the boat and three rolls of tape. Had to keep this low or hear the wife complain. [:@] Any way, instead of three rolls of tape, I got three props for an electric plane.. Go figure, don't even look the same. I called TH right up, they would send out the tape and I get to keep the props. Whatever, don't even have a plane. Think they would look a little odd sitting on the back of the Deuce. The tape showed up two days later.. Granted I live just a state away from TH. Thought it was good service of them to work so quickly.
Old 12-22-2010 | 06:47 PM
Did you remove your header yet to see if it has that flange?
Old 12-23-2010 | 09:46 AM
No i didn't remove it yet.If it works it works if not i still want the coil,cause when i bought it i bought that to.So i'm not to concered right now.If this photo uploads you'll see i have lots of time before this boat even sees water.I want to move this weather sucks.
Old 12-23-2010 | 09:52 AM
Ob nut yeah i like TH i bought a lot of stuff through the yrs,never had a problem.They're good that way prices are great.If you seen my lcs you would laugh,unless you needed something then you''d be cursing up a storm.I was in there they had 2 bottles of 10% car fuel.The place is a joke,the owner is cool.I feel bad for him,he does hardly any buisness.
Old 12-23-2010 | 07:49 PM
If it does have have the flange....just unwrap the coil....SLOWLY and CAREFULLY and EASE it on the the header.....then wrap it back up.....
Old 12-24-2010 | 12:52 PM
Yeah maybe i will take it off today and see.That aluminum will kink very easy.I'll just take my time if i do hve to do that.Thanks.I'll let you know,maybe i'll recieve the coil Monday.
Old 12-24-2010 | 03:24 PM
strip down a pice of wire ( like what is used in house ) and run it trought the tubing it will helpi it not knink
Old 12-25-2010 | 07:46 AM
advanced builder's Avatar
Or sand and salt. heat & bend
Old 12-25-2010 | 08:38 AM
fuma's Avatar
fill with water .         freeze          bend              thaw            use
Old 12-29-2010 | 08:02 PM
Fuma says F all that do thi t s and that.It's cool i got it on.Thanks guys you're all very helpul.
