Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 fastech question >
fastech question
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
fastech question
Old 05-06-2011 | 06:06 PM
scavone128's Avatar
Default fastech question
i bought a formula fastech last year and first run out the flex shaft was slipping like crazy when i tried to get in on plain i think its the collet nut. just in case i bought a new flex shaft as well but i have yet to get a coupler as the stock one seems very poor quality.http://www.offshoreelectrics.com/pro...d=aero-couplerwould this fit on the dynamite .15 and im not sure of the flex shaft size if anyone knows that would be greatly appreciated thanks.
Old 05-06-2011 | 07:52 PM
Default RE: fastech question
i have 2 fastechs,and they both had the same problem.their collets were overtightened at the factory,and then when you loosen them to lube the shaft,they wont tighten again.i just ordered a couple of proboat replacements and havnt overtightened them,havnt had a problem since.i think the flex diameter is .150.if your heart is set on OSE replacements,give them a shout or look on their forums,they're a great bunch over there,they have helped me out quite a bit.
Old 05-09-2011 | 06:14 AM
Ron Olson's Avatar
That one won't work as it's made for electric motors. Steve shows this number as the correct one but it appears to have the incorrect one in the picture. http://www.offshoreelectrics.com/pro...=oct-ocfh5mm15 . The Octura part I'm thinking may be too long to fit in place of the ProBoat collet. Aquacraft has a collet also that could go in there but I'm not too crazy about theirs either.
Old 05-09-2011 | 05:28 PM
scavone128's Avatar
thanks for the response i decided to just order the stock coupler as it will be simple i just have to make sure i dont over tighten it  now all i need is for the hudson rivers flooding to go down
