Exhaust Pressure Fittings
Can some one tell me with a picture if possible where I need to drill my tuned pipe for a pressure feed
to the fuel tank, I have a OPS 67 with a OPS silenced tuned pipe .
chombo
chombo
RE: Exhaust Pressure Fittings
Forgot to say if I have 2 fuel tanks do I have a pressure feed to each tank if the tanks are linked together.
KS
This is a macs 7.5 cut down but fitting should be in the same place for yours UNLESS its a muffled pipe, if muffled (like a cooper or macs muffled) you would drill just before the center or just before the weld so you dont get into the muffling chamber
fuel tank,pressure the first tank- feed off the second
