Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
setting c-g
Old 04-03-2014 | 06:23 AM
taildragger101's Avatar
Default setting c-g
I have a spitfire 2 with a modded 7.5 k/b. Want to check my c-g. I would like to set it around 30% of total length. My question is do i measure from rear of outboard or rear of sponsons ? Thanx
Old 04-03-2014 | 08:15 AM
Hydro Junkie's Avatar
Just curious, where did you get the 30% figure from? That sounds like the balance point of a vee hull, not a hydro
Old 04-06-2014 | 07:34 AM
Rear of sponsons. Aim for 28-30% then go jump the boat over wakes and check what the boat does. If if it jumps nose up adjust the cg slightly forward.
Cobus
Old 04-07-2014 | 03:47 AM
Jump a outboard rigger over wakes? Are you serious?
