3.5 outboard rigger?
IL
I have a outboard rigger that I can not get to come up on plane it just cavitates then jumps out of the water and then starts to cavitate again.I have moved the motor up and down, in and out and it makes no changes in it.I have a c20 prop on it maybe not enough prop?
Todd
Todd
RE: 3.5 outboard rigger?
I have no idea what a C20 prop is. It sounds like the prop is still too high up. If it has the big rear sponsons like the Prather OB 'rigger, they're probably lifting to motor too high out of the water. Just a guess, we don't have any .21 'riggers around here.
IL
It has rear sponsons on it. Should the prop shaft be lower than the rear sponsons?The cavitation plate is just a little lower than the rear sponsons.As far as what prop it is the only other markings on it are jg on the other side of the c20.
Thanks for any help you can give me on this!!
Todd
Todd
OK, what you have is an old JG prop. From my limited experience with 'riggers so far, the prop shaft should be slightly below the bottom of the sponsons. What you have is mostly a NAMBA/ West Coast boat, not too many seen East of the Mississippi. A non-lifting prop such as an Octura X438 will give you less hassle as it wouldn't cavitate as badly. Hopefully someone with experience with one of these will respond.
IL
I got a different prop on it and it runs good.That is until the flex shaft broke on the second run.Where is a good place to order parts from that has good service??
Todd
Todd
The best way that I set up my 3.5 rigger. Remove the turn fin, back off the bolt that holds the strut in position. Place the boat on a flat table, place some 1/4" shims under the rear sponsons. push the strut down to the table until it sits flat on the table(front and rear of the strut should touch the table). Lock the strut in this position. Replace the turn fin.
As for breaking the shaft, make sure that it does not have a bend near the prop stub(if so it will heat up the soider joint and break)
The best prop I have used on my rigger is the USA H10. This is a prop for a high torque high RPM engine. For the lower powered engines, get a octura X442 and round off the tips.
If the CG of your hull is too much on the rear, you may have to set the strut with the front of it a little higher than the rear of it.
The riggers are a very fast boat once they are set up, and handle well. Its just to get them set. When making adjustments, only make one at a time, and very small movements.
Good luck and I hope some of this helps
ORIGINAL: haljmac
Sounds like you are talking about an inboard. His is an out board.
