Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Unofficial Nitro Hammer Thread
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 03-27-2007, 03:07 PM
  #801
nooob
Default RE: Unofficial Nitro Hammer Thread
I just got mine. It runs around 25 mph stock.
Old 03-27-2007, 09:48 PM
  #802
eas___1990
i had a head on colision with my buddy's dumas tunnel. went 4 foot in the air doing 2-3 barrel rolls and landed upside down. lucky it was only 3 foot out hulls didnt fair so well(specialy his) mine crack about 4 inches down the v. but i almost have my "replacment hull finished and i the think i will buy the hardware sometime this week.
ps. i havent been around here in while and i am seeing alot of new faces, welcome
Old 05-06-2007, 04:03 AM
  #803
hammer99055
i have had my nh for about 6 months just got a new .18 engine installed runs very well but keeps breaking props can anyone recomend a good prop thats fits the stock shaft
Old 05-06-2007, 10:31 PM
  #804
dicko
dicko's Avatar
PM Grant Ed, he got a Berrylium prop for his, the guy he got it from even sharpened it for him. it's designed for the 18 engine's torque & rpm. it handles really well. he's running an OS 18.
Old 05-07-2007, 05:46 AM
  #805
GRANT ED
GRANT ED's Avatar
ORIGINAL: dicko
I use an Octura X-435. It was prepped by mark at props 4 U. I can recommend this prop.
Old 05-08-2007, 01:06 AM
  #806
hammer99055
thanks for the help i check it out
Old 05-22-2007, 03:19 AM
  #807
1/10nitro
I'v only just got my nitro hammer today and i dont no the best way to break it in should i use break in furl
(5% nitro) or should i use 20%
Old 05-22-2007, 04:16 AM
  #808
hammer99055
i would recomend 20%
Old 05-22-2007, 06:00 AM
  #809
GRANT ED
GRANT ED's Avatar
ORIGINAL: 1/10nitro
There is no such thing as "break in fuel" in nitro. The best fuel to break your engine in with is the normal fuel you will use. I also recommend 20%. I used 30% for a while but it made the engine very, very sensitive to needle settings.
Old 05-22-2007, 06:12 AM
  #810
1/10nitro
thanx coz when i bought my nh from hobby habbit they gave me 5% with the starter kit
Old 05-22-2007, 08:01 AM
  #811
GRANT ED
GRANT ED's Avatar
Take it back and make them give you 20%.
Old 05-24-2007, 04:43 AM
  #812
1/10nitro
thanx should i no any thing else about breaking it in
Old 05-24-2007, 07:29 AM
  #813
f16man
Hey wave walker you should name that hammer,,,,,, hop skip and jump ha ha ha
Old 05-25-2007, 07:01 AM
  #814
dicko
dicko's Avatar
heat cycle it if you can & don't listen to HH. also set your turn fins up straight otherwise you will spend a bit of time upside down(clamp a piede of straight wood to them & set them up parallel to the keel line & set the ride fins flat to start with). if you end up flipping it, bring it back in & start it up straight away after you have cleared the water out of the engine. other wise you'll have a hell of a time starting it later.
Old 05-26-2007, 11:33 PM
  #815
wave waker
ORIGINAL: f16man
people who watch me while running in the park pond call her Speedy Gonzales
Old 07-17-2007, 10:52 PM
  #816
flyboy0614
I just got a NH a couple weeks ago and finally have it tuned and running on 20% fuel. After installing a new prop on it I got about 6 minutes of run time before the prop blades just broke off, leaving me to go retrieve the boat from the middle of a lake. Has anyone else had trouble with props breaking and is there any sort of break in procedure for new props to increase their life span?
Old 07-17-2007, 11:24 PM
  #817
Ron Olson
Ron Olson's Avatar
You might be tightening the prop nut too far. Take a sliver of fuel line (about 1/8" thick) and put it between the prop and prop nut. That will keep you from putting too much pressure on it and it'll work like a lock washer.
I'd advise that you buy a metal prop for it, they don't cost that much.
Old 07-18-2007, 04:29 PM
  #818
flyboy0614
What is a good metal prop to substitute for the stock one? Also, if I go metal, are there any sort of things I need to do differently before running it?
Old 07-18-2007, 10:55 PM
  #819
Ron Olson
Ron Olson's Avatar
Try the Octura X-432 or X-435 on it. The only things that you'll have to do is to sharpen and balance it/them which isn't too hard with small props.
Old 07-19-2007, 01:55 AM
  #820
Muteki
Hi Wave Waker, I saw your videos on YouTube. I notice it was bouncing all over even though the lake was pretty calm. Did you ever fix that problem? I see they were posted a year ago. Perhaps you could post some new videos, because if it runs like that I don't want one, but other's I've seen, they glide real smooth on the water. Thanks.
Old 07-20-2007, 08:54 PM
  #821
suzukiboy
Gidday everyone
I just finished reading the whole thread.....
Some very intreresting idea's.
I received my secound hand Yello Nitro Hammer in the post yesterday.
In very good nick, except for the idiot who sold it to me left a whole tank of Nitro in it and the fuel line came off and everything is coated in Nitro including transmitter.
And a few hours of cleaning the sticky tape from the hull where the bubble wrap was.
I watched some of the video posted here and cann't wait to try it out.
Does anyone know if you can buy an original sticker kit of the Hammer?
Here are a few pics of my other RC boats.
ID:	727178   Click image for larger version
ID:	727179   Click image for larger version
ID:	727180   Click image for larger version
ID:	727181   Click image for larger version
ID:	727182   Click image for larger version
ID:	727183   Click image for larger version
ID:	727184   Click image for larger version
Old 07-20-2007, 11:19 PM
  #822
Ron Olson
Ron Olson's Avatar
Tower Hobbies should have the decals in stock or try your Aquacraft distributor in Oz for them.
Old 07-21-2007, 12:37 AM
  #823
dicko
dicko's Avatar
don't bother with the aquacraqft distributor in oz, go straight to tower hobbies.
Old 07-21-2007, 02:15 AM
  #824
wave waker
ORIGINAL: Muteki
hi there,
i really set it up to run like a dragters or bashing i would say...but if u like to have a smooth ride try to make the trim tab a lil' bit bigger and angled it until the sweet spot is found just my 2cents...but just remember with v-hull chine walkin' is norm...
Old 07-24-2007, 12:19 PM
  #825
1totrust
Hi Everybody,
I’m new here and I’d like to know if someone tried this before.
When I bought the Nitro Hammer I was pretty disappointed. The tank wasn’t air tight, and the low speed needle was so tight that the boat wouldn’t run at all when I took it out of the box. It was my first boat, after several nitro buggies, so I wasn’t aware that this boat couldn’t stand still and idle in the water. Also I didn’t know that it only has cooling for the engine when it’s moving. So before I even broke in the engine, I took the boat apart and customized it to my expectations.
First I put in a clutch from a buggy that I modified with an aluminum part, so that I can connect it to the shaft.
Then I put a nitro fuel pump in there to have cooling of the motor at all times.
It all works well and it is fun and easy to drive.
ID:	729161   Click image for larger version
ID:	729162   Click image for larger version
ID:	729163   Click image for larger version
