shockwave 36 problem
hi i have a shockwave 36 and was running great very quick till one day it flipped on me and went under the water, i took it home flushed it out put after run oil in and changed the fried radio gear. my problem now is when i run the boat it does not go and most times dies when given gas before it was like a rocket, any suggestions. p.s it starts and idles.
My Feedback: (9)
CA
RE: shockwave 36 problem
yea, check your fuel lines...you should have cleared the water out of the engine first and then fired it up right away to make sure all water was out of the engine...blow out your carb and make sure there isn't anything blocking the fuel lines
