15 cc tunnel hulls
Hi
I'm looking for a fast tunnel hull to race at my local boat club. A tunnel hull with a modified 15 cc engine would be nice but I can't find any that can take over a 11 cc. So could you reply if you know where to get a 15 cc tunnel hull.
Olin Poulson
Olin Poulson
![](/forum/images/badges/trading_plus_member.png)
There are a few options for you. If you like to build, buy the plans for JD's 47" WOF Solution. I've built a few and have run with 11cc and 13cc mod motors.
![](http://home.earthlink.net/~ob_nut/sitebuildercontent/sitebuilderpictures/sol03.jpg)
Who makes this 15cc motor? K&B makes a 16.4cc motor besides the 11cc or 13cc motors. I've never ran a 16.4cc motor, but have heard they shake the prop shaft apart nearly every run.
If you are set on running the larger motor, try a Bandit Desperado. They were made for a gas (petro) motor and should handle the larger nitro motor.
Link to [link=http://www.banditboats.com/tunnel.htm]Banditboats[/link]
![](http://www.banditboats.com/desperado56.jpg)
DPI made a large tunnel in years past. You'll have to watch Ebay to find those as DPI is oob...
Good luck..
Mark..
Good luck..
Mark..
