Shockwave 36 Questions
Hey
Is there any way to make the shockwave have dual tuned pipes????? If not is there a wet tuned pipe for it? and also can you get docking lights for it too? I thought if i could they would look real cool when i took the boat onto the trailer i made.
Dan
Dan
RE: Shockwave 36 Questions
Well Dan, you could plumb up some fittings to give it dual exhaust but twin tuned pipes would be a major project. I'd avoid water cooling or the exiting of the water through the exhaust. The problem lies in when the water would have a chance to drain back into the engine.
As far as lighting goes, you should be able to do whatever you want, docking lights, navigation lights or even neon looking lights in a variety of colors. RAm may have the lights that you're looking for. www.ramrcandramtrack.com
Hey
They don't have any docking lights. Thanks anyways Ron. I will try to find some and if i get lucky they will come in stainless steel
Dan
Dan
Is there a casing????? if not i guess i can just drill holes in the fron of my shockwave hull when i am gonna put them.
Dan
Dan
