Thunder Cat 31
#2351
MO
RE: Thunder Cat 31
ORIGINAL: solo2004
hi i found this to be the best prop for my t cats all got same prop on alloy is about 3- 4 mm fron diy shop
Graupner 48mm x 3/16" bore drive dog carbonfibre hydroprop part nub H- 2317 -48
#2353
RE: Thunder Cat 31
ORIGINAL: SinCityInc.
Some more photos.....enjoy
Wow! That is a very impressive set-up. Very cool. Congratulations!
I have a lot of questions about it, but I'll take 'em one-at-a-time for the moment. Right now, I am very, very interested in knowing more about how you set-up those dual fuel tanks.
Why? Well, I was at the lake yesterday, and I was having repetitive problems with hydro-lock, constantly having to remove the glow-plug and drain the engine before I got it started. It strikes me that the way the OEM fuel tank is configured, it allows gravity to push too much fuel into the fuel line / carb before you can get her started, thus, locking-up the engine. After she's up and running, it is probably a very good set-up.
So, (a) What fuel tanks are those (manufacturer and part number)? (b) Were the fittings, enabling the use of two tanks side-by-side, easy to come by? (c) How does this set-up work for you? (Quite well, I'd guess.)
TOPIC CHANGE:
New to all this, I’ve been trying to Google for info on the RC boat “scene†at Sunset Park in Las Vegas. (Are there other locations nearby?) I don’t think I’ve yet located the link / website, which provides ALL the information (hours of operation, rules & regulations, etc.). Can you direct me to such a website? (It is inevitable that I make the pilgrimage there at some point.)
Thank you,
Caliban
#2354
RE: Thunder Cat 31
Hello, Everyone:
Okay, this is a head gasket (head shims) & percentage of nitro question:
When shipped, the ProBoat manual states, "Several head shims are added at the factory to make the engine easier to start when new."
Hmmm, okay, mine had two installed, one of the (aluminum?) .2mm (DYN6455) and one of the (brass?) .1mm (DYN6454). I've been using the Blue Thunder Sport, 20% (DYN2320).
After I broke-in the engine a bit, I removed the .1mm gasket/shim, and left only the .2mm.
I know that as you increase the nitro percentage, you have to decrease the compression ratio (lower nitro content = higher compression ratio; higher nitro content = lower compression ratio).
So, I'm thinking the engine is broken-in enough now, that I want to try 30% (for the first time). Okay, how many head shims should I add? Again, I am now running ONLY the .2mm. So, add, say one .1mm - or - add, say, two .1mm?
Is there a "rule-of-thumb" here, or, am I simply gonna have to experiment?
Caliban
Caliban
#2355
FL
RE: Thunder Cat 31
purely my own preference. i ran just the aluminum head shim with 30% and i now run the aluminum and one copper one with 65%. i believe the aluminum one is supposed to always be there.
#2356
1 Post
RE: Thunder Cat 31
Well, I was at the lake yesterday, and I was having repetitive problems with... (nitro engines)
#2357
RE: Thunder Cat 31
ORIGINAL: lomdel
That's exactly why I converted my TC31 to brushless electric power...
Does this mean to say that you don't like the challenge and reward of mastering these obstacles?
Caliban
#2358
RE: Thunder Cat 31
ORIGINAL: black talon
Hmmmmm, okay. I'm running just the aluminum shim now (.2mm) with 20%. So, are you saying I can just leave it alone, and run 30% with just that one .2mm shim? I guess if you are running 65% with that set-up, it should work.
Curious: Did you try / experiment with different head shim configurations as you went to 65%?
Caliban
#2360
RE: Thunder Cat 31
hi do running 65 % make a big difference than running 20% say for the extra cost and stess on the engine i myself only run 10 % which i find is plenty for my needs
#2367
RE: Thunder Cat 31
The fuel cell that comes with the boat from factory is crap....total crap. I ordered a second tank my self (oem) and it leaked worse than the 1st one so it was time to replace it. The 2 cell system works very well for me on this set-up but you only put fuel in 1 of the cells, the other cell is to keep constant pressure on the line. you can order these from Tower Hobbies, they are Sullivan fuel cells part # SS6 (Sullivan seamless 6oz) and the fittings come with the tanks. I have thrown a close-up of the fuel system on here so you can see how it is set up. With the twin tanks sitting where they are the boat is off it's CG but the same problem exist with the single leaking tank that came with it...you could always relocate the fuel cells to either side to get it to balance out a little more.
#2368
IN
RE: Thunder Cat 31
ORIGINAL: solo2004
#2369
FL
RE: Thunder Cat 31
the fuel tanks as cast did leak around the outlet but if you got a good one you are good to go.it took me 3 to get a good one and i am still using it. if you want you can install a 1 oz boost tank before your fuel tank if you wish. but for cg issues i prefer just one.
#2371
RE: Thunder Cat 31
Hey, thank you very much for the effort in posting those images; much appreciated.
I understand the concept of an open / empty cell, in order to maintain pressure, but I don't understand why one could not fill both cells / tanks with fuel and, thus, maintain the center of gravity / balance. Why wouldn't that work?
For whatever it is worth, my OEM fuel tank certainly is not leaking pressure. I put an O-ring in the cap, just as a back-up. But, I think the fuel feed exiting the bottom of the tank is not a good thing. It seems to me that is the source of the flooding / hydro-lock issue I am having.
Caliban
#2372
RE: Thunder Cat 31
Hmmmmm, I'm gonna have to cogitate on this one some more. I'm not wild about any solution, which would set the cg askew.
Those of you "out there," who are still using the OEM fuel tank, are you having problems with that configuration contributing to hydro-lock?
Caliban
#2374
RE: Thunder Cat 31
prime it, pinch it off and when it catches, open it. or tilt the boat so the fuel level is below the carb.
Well, that is what I was beginning to think; just get a pinch clip and be done with it. I have a unique way of making a larger project out of something than need be. Oh, well!
Caliban
#2375
MO
RE: Thunder Cat 31
Carbon fiber was used in the center under the motor to strengthen the weak tunnel hull bottom...prone to twisting and cracking from beatin it on the water, not to mention the occasional flips & barrel rolls it like to pull.
