Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 Outboard Help >
Outboard Help
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Outboard Help
Old 08-20-2006 | 12:00 AM
Default Outboard Help
How do I remove the shaft were the propella goes onto... its sized up and hard to turn :@ its not the motor the shaft is bent its on a lawless 3.5 lower unit and then next question will a K&B shaft fit?? Cheers Daniel
I should add were should I buy another shaft from??
Old 08-20-2006 | 07:08 PM
Default RE: Outboard Help
ORIGINAL: poobee
it goes to opposite direction, so if ur goin to remove it, it should be clockwise turn...i got 7.5 lawless lower unit and k&b shaft fits i'm not sure for 3.5 lower unit.
Old 08-22-2006 | 10:02 AM
another question there is a part with some pins in it how do i remove the pins???
Old 08-22-2006 | 11:29 AM
A K&B 3.5 flex shaft and stub shaft will fit on the Lawless lower unit. The pins can be punched out with a small rod.
JD
