huh? pro boat bj 26
i was breaking my pb black jacik 26 in after 4 runs brought it in shut it off refueled checked the radio (worked fine) crunk it up and it got a mind of its own shut it off and the radio/servos worked properly crunk it up thery went wild again went to a different location and it did the same thing whats wrong?
IL
Well I have a TC31 and my am radio is goofy, it just is a nervous twitching mess i plan on getting a new fm synth or a spectrum. I cant help ya otherwise sorry.
Paul
Paul
IN
ORIGINAL: jonnygofast15
ur blackjack 26 got nervous due to the scary stuff next to her
batt check?..it might be.
Check radio box to ensure completely dry, as on my 2 week old Miss Elam after 2nd run I had identical problem. Radio box appeared bone dry but was not until I disassembled and took everything out that I noticed receiver and servos were damp. Have since dried evrything out and everything works fine!
it does that when its running and its not twitching its go wide open and turn all the way but when you cut the engine off it listen completly crank it up and it listens none what so ever?
ill try to take a vid when i get back from eating.
-jon
-jon
I agree.... sounds like a radio glitch to me, seems to be with engine running, vibrating the boat. Check all your connections, and look for any moisture.... very importanat that the radio be dry.
OH
Mine does the samething but not that bad.It will do it on the glow ignitor is attached too,must be normal for this,I gess.But mine makes a buzzing sound!! Any idas Ron on this?
IL
If you where to goto a spectrum radio would these problems be fixed? the twitching and buzzing, over a proboat AM radio?
Thanks Paul
Thanks Paul
The Spektrums are another ball game altogether. We've had and I've seen problems with those radios. The early ones had a problem where the water reflected the signals drastically shortening radio range. Save your money for now and just get a decent FM radio.
We have had AM radios glich over and over at our lake most of us have gone to FM and the problem went away also I have seen the specktum radios glich very badly around water I have a 1/12 Miss Bud a Blackjack and a Thundercat and replaced all the radios with FM
