Dynamite .15 needle settings!
Can anyone help with factory settings for a Dynamite .15? As manual says 2 1/2 for HSN and 7 for LSN. This can't be correct for LSN, as if try unscrewing anymore than 5 - 6 turns needle pops out of threaded housing!
IN
RE: Dynamite .15 needle settings!
ORIGINAL: CARIMALI
OH
It's 2 1/2 to three turn out on your HSN screw.Go too the MIss Bud thread that is on it too.Go to page 4 and you'll see the Miss Bud thread it eight pages long on stuff like that and other upgrade and mod to get your boat to perform better.GO check it out!!!!!
This is what I have seen on a lot of motors. Flush with the throttle lever.Then turned in 1/2 turn this is the base setting on OS to regain neutral setting. Dave
Thanks Dave, after alot of frustration finally got it tuned to where I want it. Worked out to be 2 1/2 turns out on HSN and 1 /3/4 out on LSN (which was roughly 1/4 turn in from flush position on LSN....so you were spot on!)
I was havin trouble for a bit with my .18 didnt know there was a broken motor mount everytime I would try to launch it would die I though it was lean, then maybe rich so I started playin with the LSN no help then I relized the motor was bouncing around and causing it to close the throttle all the way so took it home and fixed the mount reset LSN to neutral and she ran fine the next day.
