Baby Rigger Build Log
#51
IL
RE: Baby Rigger Build Log
I use a .130 flex on my .12 rigger, but I dont have any idea how strong your motor is? Isnt the transom 1 piece of wood 1x3 roughly?
Paul
Paul
#52
ORIGINAL: gooycheese
Paul
Paul
Dan
#53
IL
I followed the .12 rigger building plans on the web sight, its up to you if you want to. I found it to be helpful with the order of operations and why thing are the way they are. And yes you do need some foam (pink/blue) the foam need to be able to be sanded without falling apart.
Paul
Paul
#54
Alrite thanks ill just have to find some I know they have it at my school but i am assuming that it costs alot of money and I won't be able to have some. Hmm do i really need rear sponsons with all this power because i thought they were just for underpowered boats that need help getting on plane? Ok whatever im out
Dan
Dan
#55
TX
My understanding is that the rear sponsons help the boat in turns, and that they should not really be in the water under full power.
But on top of that, it seems they would help keep the boat afloat when the boat is stopped. They say your boat should float when it is full flooded with water (to include the radio compartment). Not sure of it would without the rear sponsons...
But, I have seen pictures of boats without them...
Sean
Sean
#56
Hmm taylor just told me that the 9XL would be too big, ok.... SO I think i may get a 540 7L so i ight be able to race on internet racing on rum runners in the N2 hydro class.
Dan
Dan
#57
hmm progress is amazingly slow, i still need to get that foam!!!! Ok i still only have a few parts of the tub to the rigger done. I have a question can you use fuel tubing as a stuffing tube?
Dan
Dan
#58
WI
I dont think that you should, I have never done it so I dont know but I would think it wouldnt be as slick at teflon and heat up, maybe melt even but idk!
#59
TX
Just as an FYI about terms, I am pretty sure the "stuffing tube" is the metal tube that runs from your motor down to your strut. I think you are talking about the "teflon liner."
And as was already said, I would say that fuel tube would not work. Fuel tube is rubbery, or sticky. Liners are supposed to be slick.
Sean
Sean
#63
I FINALLY GOT FOAM!!! I am gonna use a liner and i am also going to have to buy LOTS of parts from the usa. Could you guys reccomend some flex cables /liner/stuffing tube from tower, because they ship international. I just bought some balsa for the rear sponsoons, and the bulkheads. can i use this balsa for the front sponsoons or do i have to use plywood. I would really like to use balsa because i can buy it in strips and not huge sheets.
Dan
Dan
#67
TX
ORIGINAL: Dan Collins
can i use balsa?
Dan
can i use balsa?
Dan
I do have some balsa on the inside of the sponsons on my larger boat.
Sean
#68
Oh because on the plans it said foam with ply covering or balsa for the rears, and i duno 4 the front
i am building the 6 cell version. Do you have any guesses for the thickness of the wood, or should it be the same as the baby rigger?
Dan
Dan
#69
Could someone please tell me what thickness of wood is needed for the top, bottom, and the different sides of the sponsoons? and i just bought some very sticky double sided tape will it work for attaching the sponsoons?
Dan
Dan
#70
IL
Ok if this is a .12 rigger then i would say you will use 1/32 on all sides except the side the boom tubes enters. I am just guessing on this if its for a .21 i would guess 1/16 all sides and 1/8 boom tube side. Also dont forget to consider the turnfin need to be reinforced on the inside of the sponson. I am using double sided servo tape to attach my rear sponsons.
Paul
Paul
#71
IL
On my .12 rigger sponsons I used for the sandwich 1/16" ply 1/8" balsa 1/2" foam 1/8" balsa 1/2" foam and then wrapped everything with 1/32 ply.
Paul
Paul
#72
Ok Thanks Alot!! Does anyone have any Ideas for the thickness for the bottom of the boat? I will go out and buy that today.
Dan
Dan
#74
KS
mine are from the inside are 1/16 ply-1/2 foam-1/4 balsa-1/2 foam, skinned in 1/32 ply.. Tub outside's 1/8"ply doubled in engine bay only, top and bottom 1/32" ply..transom if i remember 1/16 doubled with 1/8 ply (.12 rigger)
#75
Ok thanks alot. I will go out and redo some things, i thought at first i could make everything out of 1/8 Ply, so i bought a whole sheet.
Dan
Dan
