crunchy sound?
NC
last night i had a quicky with my .16 cen baja boss all seem well it ran fine seemed real strong.ran almost whole tank coasting back to shore just got my piggise wet a little. when i got to the garage 1 min later to burn off access and give after oil . and started it, it sounded a little crunchy goosing the idle a little it cleared but returned with lower rpm,clearing it again with a plip of the throttle. i got the old "get out of the garage" just as i pulled the manifold and removed engine from hull. pulling cord with plug out it i didnt feel or see any friction or scoring on piston. hope i can fix but i quess ill have to tear it down for the first time .any quesses on what it might be going on
My Feedback: (12)
SC
Typically, a crunching sound could be bearings. Another possibility could be a rusty flex shaft. How does the engine feel if you turn it over by the crankshaft? Same question for the prop shaft, does it turn freely? If you feel any roughness at all when turning the crankshaft, it's usually time for new bearings. Another slight possibility is if you're running high nitro with a plug that's too hot, you could be getting preignition. Do you see little pock marks on the top of the piston? These are a few possibilities, other people will probably add to the list...
NJ
ORIGINAL: G-1
Maybe there's a mini Sandy Duncan in there snackin on some Wheat Thins.......
crunch crunch crunch
